  3. Extract the number of the top most metal layer of a cell...
  • Views 16443
Extract the number of the top most metal layer of a cell using SKILL
maheshwaran
maheshwaran over 7 years ago
I am fairly new to custom design and SKILL. I have a requirement to extract the number of the top most metal stack for processing for e.g. if a cell a total metal stacks uptill M14 I need to know that the cell's highest metal stack is M14 along with the cell name, If a cell has upto M12 my output should be M12 with the cell name. Is there way in SKILL to do that? if yes, Could anyone help me?
Mahesh
    Just threw this together:
    /* abGetHighestLayer.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jun 17, 2019
    Modified
    By
    Find the highest layer of a certain type (defaults to metal) in
    the design.
    abGetHighestLayer() => "Metal4"
    abGetHighestLayer(?acrossHierarchy t) => "Metal6"
    SCCS Info: @(#) abGetHighestLayer.il 06/17/19.21:05:07 1.1
    * abGetHighestLayer(@key (cv geGetEditCellView()) (function "metal") *
    *                          acrossHierarchy)                          *
    * Find the topmost layer with the given function (defaults to metal) *
    * in the given cellView (defaults to current), optionally looking at *
    *                  all in the hierarchy if needed.                   *
    procedure(abGetHighestLayer(@key (cv geGetEditCellView()) (function "metal")
            acrossHierarchy)
        let((tf topToBottom usedLayers)
            ; Figure out the order of the layers matching the given function
            ; and put it in reverse order
    	tf=techGetTechFile(cv)
            topToBottom=reverse(
                mapcar('car
                    setof(layerFunc techGetLayerFunctions(tf) cadr(layerFunc)==function)
            ; Now collect all the layers used in the design. If ?acrossHierarchy t
            ; was provided, then include those in lower level cellViews (if opened)
            usedLayers=makeTable('usedLayers nil)
            foreach(lpp cv~>lpps
                when(acrossHierarchy || !zerop(lpp~>nShapes)
                    usedLayers[lpp~>layerName]=t
            ; Find the first top to bottom layer that's in the design
            car(exists(layer topToBottom usedLayers[layer]))
