  3. hiCreateListBoxField,callBack
  • Views 4113
sritha
sritha over 7 years ago
 I have created the ListBoxField
box=hiCreateListBoxField(?name box
                                                 ?choices '("pfets" "nfets" "res")
                                                  ?callback "")
for the given choices  I need to trigger different  functions for each choice list.  Example: if  Iselect pfets in the appeared listbox field then it has to trigger pfets() function and  if I select nfets then it has to trigger nfets() function and so on. (pfets() and nfets() are user defined functions)  How to achieve this using callback?
  • mbracht
    mbracht over 7 years ago
    well even I'am not Andrew ;-) I think I can answer this. The information about the selected item is available in the listbox callback so from there you may dispatch the required function:
       ?name 'box
       ?callback (lambda (@rest args)
             (case (car (car args)->value)
                ("pfets"
                   (pfets)
                ("nfets"
                   (nfets)
                ("res"
                (res)
             t
    Andrew Beckett over 7 years ago in reply to mbracht
    I'm struggling to get a post to reply to this thread to work - I had a slightly simpler way of doing what Max suggested. I'm working with our IT to figure out why my post won't go through.
    Andrew Beckett over 7 years ago in reply to Andrew Beckett
    Hopefully the post will work this time.
    One approach is this:
    procedure(MyListBoxCB()
      let((box)
        box=car(hiGetListBoxValue(hiGetCurrentForm()->box))
        when(box
          errset(funcall(concat(box) /*... extra args to function here ... */ ) t)
    Then change the callback to "MyListBoxCB()". This code retrieves the selected value from the field (only the first, because I'm assuming only single selection is enabled), then converts to a symbol and calls the function with that name using funcall. I wrapped it with an errset in order to catch any errors triggered during the function call and display them.
    A second alternative is using something similar to the approach that Max took but putting the function directly in the callback (i.e. using a lambda to avoid having a named function):
      ?name 'box
      ?callback lambda((field scope)
        errset(funcall(concat(car(hiGetListBoxValue(field)))) t)
    By the way, I'm not the only person here, so best not to post questions assuming that it is only me that will answer!
  • sritha
    sritha over 7 years ago in reply to mbracht
       I tried with your snippet,but it was showing error as Error : eval not a function "pfets".
    Andrew Beckett over 7 years ago in reply to sritha
    Er, that's because you haven't defined a function called pfets! You said that there were user-defined functions called pfets, nfets, res etc. If you do:
    procedure(pfets() printf("HELLO pfets\n"))
    procedure(nfets() printf("HELLO nfets\n"))
    procedure(res() printf("HELLO res\n"))
    The code is simply trying to call the function and if it doesn't exist, it gives an error. If you only want to call the function if it exists, you could do:
      ?name 'box
        letseq(
          ((value car(hiGetListBoxValue(field))) (funcName value && concat(value)))
          when(funcName && isCallable(funcName)
    This also checks that a value was specified (the earlier value did that, but I omitted it from the inline version - this can happen if you use ctrl-click to deselect any item in the listbox).
