  3. How do you "smash" a list of lists into a single list?
  • Views 2063
CADcasualty
CADcasualty over 7 years ago
I use a lot of lengthy awvPlotWaveform commands in my Ocean scripts and I'm constantly wrestling with lists for strips and colors etc. where I'm suffering with out by one counts and other such annoyances. I had made a post previously whereby Andrew Beckett provided me with a way to make a list of repeated elements using:
procedure(RepeatElement(element ntimes)
let((result)
for(i 1 ntimes result=cons(element result))
result
but now I'm finding myself wanting to make a list made up of a repeated sequences. Say I make a list of colors xx=list(Red Green Blue) - I want to repeat that 8 times so that I end up with a single list containing 24 elements consisting of (Red Green Blue Red Green Blue Red Green Blue ... ). How do I do this?
    procedure(RepeatList(theList nTimes)
      let((result)
        for(i 1 nTimes result=append(theList result))
        result
    So RepeatList('(Red Green Blue) 4) gives you:
    Green Blue
  • CADcasualty
    CADcasualty over 7 years ago in reply to Andrew Beckett
    Thanks that works great! Based on your face-palmingly simple response it's clear that the underlying issue is that I'm a lisp novice and that I didn't know about the append function (although I did try several search attempts before resorting to the forums). Apologies for asking such baby questions (I work in a small startup and nobody here knows lisp very well). Please say so if I'm crossing any line - you're the best support I have around here and the last person I need to tick off...
    Andrew Beckett over 7 years ago in reply to CADcasualty
    No need to apologise - your question was very clearly posed and no effort to answer. I mainly tend to get irritated by poorly asked questions where it takes much longer going back and forth because I have to guess what is being asked. I know not everyone knows SKILL that well (although you don't really need to know LISP to use it), so this all adds to the pool of human knowledge that people can search and find!
