  3. leMarkNet() excluded purpose layers problem
  • Views 15934
Juan Pons
Juan Pons over 7 years ago
I would like to use the Exclude Purpose info that it can be set in the leHiMarkNet() menu, but with leMarkNet() function. I tried to define this exclude purpose layers in the optionFile but leMarkNet() seems to not be using this info. I also tried to set the environment variable like this: envGetVal("layout" "markNetExcludePurposes" 'boolean t) but it does not work either.
This is the line I have in the option file that is supposed to define the exclude purpose layers:
excludePurposes(
blockage bridge boundary grid keepout label net nobias slot slotPath text track
I would appreciate any help.
Regards, Juan.
  • Juan Pons
    It is possible to use the exclude purpose information with leMarkNet() function? I need it to paint a net without painting for example a resistor which can be done if leMarkNet has into account the exclude purpose layer "keepout".
    I would really appreciate any help..
  • Amar Kumar
    Amar Kumar over 6 years ago in reply to Juan Pons
    Hi Juan,
    I am also facing the same problem. Looks like there is a bug with "leMarkNet" optionFile argument. It doesn't take every purpose given.
    So I jumped to "preXY(coordinaeList) leHiMarkNet()". I am modifying "<workarea>/.cadence/dfII/markNet/<pdk>/markNetOptions" file with required data and using the command to mark in the layout.
    It works for me.
    You can go through below post for more details.
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/38418/specifying-options-for-lemarknet-with-skill-interactively
    Amar
    Andrew Beckett over 6 years ago in reply to Amar Kumar
    This issue has been recently reported to R&D (I can reproduce it) via CCR 2188611 and will be fixed in the IC6.1.8/ICADMV18.1 ISR9 hot fix which is due to be available at the end of this month (January 2020).
