  3. list all power pin names and coordinates relative to the...
  • Views 16543
list all power pin names and coordinates relative to the top level
Rick Mattern
Rick Mattern over 7 years ago
need to find all of the power or all pin names and coordinates in relation to the top level for Voltus.   There a couple on the support site but either they give the coordinates but not name or the one that should show both has a coding error.   Article Number:20451957  which has been reported.
    I just tried that article, and it appears to work. So not sure what coding error you're referring to (the case you filed doesn't say either - just says there's a coding error)?
    I tried both copying and pasting the code from the text of the article, and using the file attached to the article. Both were OK.
  • Rick Mattern
    Hi Andrew - sorry I left that out....
    \i myvar=CCSPinsTransformedToTopLevel()
    \e *Error* get/getq: first arg must be either symbol, list, defstruct or user type - 0
    \p >
  • Rick Mattern
    Rick Mattern over 7 years ago in reply to Rick Mattern
    think I found the issue.    The original code had the pin LPP as drawing which is valid but for this technology, we use LPP of pin.   Once I changed it to "pin" it started to work.   I would have expected to return nil instead of posting an error.
    Andrew Beckett over 7 years ago in reply to Rick Mattern
    Hi Rick,
    You should be able to do (looking at the code):
    CCSPinsTransformedToTopLevel(?myLayer list("yourLayer" "pin"))
    I didn't get that error with pins on purpose pin, so I'm not sure that's the reason. I was just wondering whether mosaics might cause the issue - not sure though. I'd probably have to see the data that is causing the error (it's not my code). So I suggest you continue with your follow-up on this via customer support that you've already initiated.
  • Rick Mattern
    Rick Mattern over 7 years ago in reply to Andrew Beckett
    Hi Andrew - thanks for the quick response!   I tried deleting and re-entering   drawing   and it then worked so maybe theres a control character in the code or something???    I will follow up with support.
    Thanks again
    Rick
