  3. How can a Procedure be used in Ocean Output Expressions...
  • Views 15889
How can a Procedure be used in Ocean Output Expressions?
Aynaz
Aynaz over 7 years ago
I am trying to clean up the output expressions in my OceanXL file by defining and using a procedures to replace the repetitive expressions. However, whatever I try, I keep getting Undefined function Error and the calculation gives eval err... as if it does not pick up the Procedure or does not recognize it as a Procedure. Here is what I am doing:
procedure( calc_dco_start_time(dco_node supply)
          cross(VT(dco_node) (0.5 * supply) 5 "rising" nil nil nil)
         ) ;proc
ocnxlOutputExpr( "calc_dco_start_time(\"DCO_PHASE<0>\" VAR(\"VCC\"))" ?name "start_time" ?plot t ?save t)
and here is all the things I have tried so far:
1) Since it didn't work having both the procedure and the outputexpr in the body of my ocean script, I tried putting the procedure in a separate .il file, meas_funcions.il, and doing load("meas_functions.il") at the body.
2) I tried using (defInitProc "calc_dco_start_time" 'calc_dco_start_time)
3) I added load("meas_functions.il") to ~/.oceanrc file
4) I added load("meas_functions.il") to ~/.cdsinit
Can a procedure be called inside oceanxloutputexpr or not? If so, what is it that I am missing here?
I am using Cadence IC618 and running sims with Spectre APS version 18.1. Not sure if it makes a difference or not, but I am running ocean from unix command line.
Thanks a lot!
Aynaz
  • Aynaz
    Turns out there was a syntax error and option 3, loading the function file (with full path, if it is not in the Home directory) into .oceanrc should have worked!
    I was missing a "/" in the net name: calc_dco_start_time(\"/DCO_PHASE<0>\" VAR(\"VCC\"))
