  3. Is there anyway to lock the schematic view and make it invisible...
  • Views 17495
Is there anyway to lock the schematic view and make it invisible?
lbodepu
lbodepu over 7 years ago
Hi ,
I am looking for a skill command that can make the schematic view invisible and only the symbol visible?
One way is to use hspice sub circuit encrypted.
But every time that I intend to run the ADE simulation I have to upload the .scs file. So I am wondering if there is a way around it to automate it as much as possible.
Lavanya
    Hi Lavanya,
    I'm not sure what this means. If you are hoping to have an invisible schematic to protect your IP somehow, that's not going to work. You can't encrypt the schematic database (if that's what you're asking).
    You're also talking about encrypted hspice sub circuits, and then talking about ".scs" files (which are for Spectre).
    So what are you actually trying to do?
  • lbodepu
    lbodepu over 7 years ago in reply to Andrew Beckett
    Thanks for clarifying the schematic encryption.
    Now, Is there anyway we can automate adding .scs files everytime we invoke an ADE.
    Lavanya
    Andrew Beckett over 7 years ago in reply to lbodepu
    You can save the setup in an ADE state, or a maestro view? It's not clear what you're trying to do, or what these files that needed to be added every time are for?
  • lbodepu
    I am trying to write a skill script that adds the .scs files in the model libraries in the ADE.
    Lavanya
  • lbodepu
    lbodepu over 7 years ago in reply to lbodepu
    The scs file is the encrypted file generated by spectre_encrypt.
    Lavanya
    See this post: Re: RE: regarding model files setup in IC615
