  3. highlighting bbox
  • Views 18602
highlighting bbox
RAGHU2634
RAGHU2634 over 7 years ago
I have dbid of shape & it's bbox.Is it possible to highlight the shape using bbox  using preferred markNetColor.
Raghu
    Andrew Beckett over 7 years ago +1
    cv=geGetEditCellView() hs=geCreateHilightSet(cv list("y0" "drawing")) ; pick the layer-purpose-pair you wish to use. hs~>enable=t geAddHilightFig(hs objId) ; objId is the dbId of the object you want to…
    Andrew Beckett over 7 years ago in reply to RAGHU2634 +1
    You can either use a layer-purpose with a thick line defined (I think - I didn't test recently) or use halos: geSetHilightSetHaloParameters(hs "over" "plain" "thin" 20) (there's "thick" too but that…
    hs~>enable=t
    geAddHilightFig(hs objId)  ; objId is the dbId of the object you want to highlight.
  • RAGHU2634
    RAGHU2634 over 7 years ago in reply to Andrew Beckett
    HI,
    Thanks Andrew. It is working. Is it possible to add thick highlight ?
    Raghu
    (there's "thick" too but that's pretty thick). See the documentation for info on the controls.
  • RAGHU2634
    I tried to delete/remove this markers using below command but it is not working
    geDeleteHilightSet(hs)
    Raghu
    Yes it does (I do this all the time, and I just checked with the code above, and it works perfectly). I suspect you probably created more than one hilight set and so you've overwritten the hs variable with a newer hilight set, and have lost track of the older hilight set - so you can no longer remove it because you don't have a handle to it any more?
    If you do that, you'd just have to close the window and reopen. If you manage it properly though, this wouldn't be an issue.
