  3. Info on abeLayerFromNet and abeLayerFromShapes function
  • Views 16797
psill000
psill000 over 7 years ago
I am just looking for some understanding about the function abeLayerFromNet.
Does the function get only cellview objects on the net or does it extract from the hierarchy?
Does the abeLayerFromShapes take the hierarchy path of a shape or only at cellview level?
Paul
    Paul,
    From a quick experiment, it follows the net through the hierarchy - assuming of course the net is connected to the instTerms of the instances and there are nets within those instances which are connected to the terminals. So it doesn't extract - it uses the connectivity information already in the database.
  • psill000
    psill000 over 7 years ago in reply to Andrew Beckett
    Is there a way to add a property to the abeLayerToCellView shapes generated or can I put the shapes to a scratch cell?
    Paul
    Andrew Beckett over 7 years ago in reply to psill000
    Paul,
    If you look at the documentation for abeLayerToCellView you'll see that you can specify the output cellView (in more than one way) and that the function returns a list of shapes that are created (so you can put a property on them easily, or store them in a group).
    I just noticed I didn't answer the original question about abeLayerFromShapes. I think the answer is no - it just creates the abeLayer object from the coordinates of the shapes passed in. You can however create layers from hierarchical shapes by using abeLayerFromCellView which allows the number of levels of hierarchy to be specified.
  • psill000
    I am getting an error when I try to put a property on the shapes
    abeLayerToCellView(layAndNot "M1" ?purpose "cfill")
    tileIter = abeTileIterator(layAndNot)
    while(tile = tileIter~>next
    ;geSelectObject(tile)
    dbCreateProp(tile "viaProg" "boolean" t))
    CIW
    *Error* dbCreateProp: Invalid database object - geoTile:236a7030
    Paul
    That wasn't what you asked earlier. You can put properties on the result of abeLayerToCellView because these are shapes in the database. You can't put properties on the "abe" objects themselves because these are virtual objects that only exist in memory and aren't db objects. There's not really any benefit in being able to put properties on these. The error message is pretty clear - you're trying to add a property on a geoTile object which isn't a database object.
