  3. Intercept custom skill function before execution
  • Views 15892
adc23
adc23 over 7 years ago
We have a custom skill script which can be called either through a menu or a keyboard shortcut inside the virtuoso schematic editor. This skill function reads a cadence variable which is set in our cdsinit file. This variable defines the root directory of where the output of the function is placed. The remainder of the directory is derived from the cell name.
I am not able to change this function as it is used company wide. However, our team wants the option to steer the output of the function based on the virtuoso library as well as the cell. I've identified two possible ways of doing this but haven't been able to work out how to implement either of them:
  • write a function which is called any time a window gains focus. If the window is a virtuoso schematic window, update the cadence variable with the appropriate destination for that window.
  • create a trigger which catches the function before it's called, and modify the variable before calling the function.
I can't see anything in the documentation about knowing when a window gains focus - only how to set the focus of a window. I also don't have enough SKILL knowledge to understand the custom triggers. Are either of these solutions viable - or, is there a better way to achieve the same result?
Alistair
    Andrew Beckett over 7 years ago +1
    Hi Alistair, There is a trigger which can be registered when the current window changes: procedure(CCFcurrentWindowChanged(winNum) let((winId cv) unless(winNum==0 winId=window(winNum) ) when(winId…
    Hi Alistair,
      let((winId cv)
        unless(winNum==0
        when(winId
          cv=geGetEditCellView(winId)
          getWarn()
          unless(cv~>cellViewType=="schematic"
            cv=nil
        when(cv
          sprintf(ROOTDIR "/tmp/%s_%s_%s" cv~>libName cv~>cellName cv~>viewName)
    hiRegCurWindowTrigger('CCFcurrentWindowChanged)
    ; second trigger approach needed for new windows (i.e. if you open a schematic design) because
    ; the current window trigger is invoked before the cellView is installed in the window. Also
    ; if you descend or ascend in a window, the current window trigger doesn't get called - but this
    ; will
    procedure(CCFschPostInstall(args)
      sprintf(ROOTDIR "/tmp/%s_%s_%s" args->libName args->cellName args->viewName)
    deRegUserTriggers("schematic" nil nil 'CCFschPostInstall)
    The alternative is to store away the original function and redefine a new version with the same name which sets the variable and then calls your stored function. Something like:
    unless(getd('MyStoredFunction)
      putd('MyStoredFunction getd('TheOriginalFunction))
      sstatus(debugMode t)
      procedure(TheOriginalFunction(@rest args)
        let((cv)
          cv=geGetEditCellView()
          when(cv
            sprintf(ROOTDIR "/tmp/%s_%s_%s" cv->libName cv->cellName cv->viewName)
          apply('MyStoredFunction args)
    You'd have to change the function names in this second approach.
  • adc23
    adc23 over 7 years ago in reply to Andrew Beckett
    Thanks, this allows me to do exactly what I need it to.
    Alistair
