  3. How to convert '() to list()
  • Views 1472
WTony
WTony over 7 years ago
I would like to convert a list from no evaluation to evaluated list. h ow can I do that.
my code is :
yhwDrDefinePacket = list(
;( DisplayName  PacketName                   Stipple    LineStyle  Fill       Outline    [FillStyle])
'( display      M1_drawing                   metal1S    solid      blue       blue       outlineStipple)
'( display      M1_label                     blank      solid      blue       blue       outlineStipple)
'( display      M1_pin                       X          thickLin2  blue       blue       X         )
foreach(yhwPacket yhwDrDefinePacket
 if(drFindPacket("display" pcExprToString(nthelem(2 yhwPacket))) then
  drSetPacket(yhwPacket)
when I run the code, it show the error below:
*Error* drSetPacket: too few arguments (at least 6 expected, 1 given) - ((display M1_drawing metal1S solid blue ... ))
So instead of passing 7 arguments, it pass just 1 arguments
Thanks for any help
Tony
    Tony,
    I think you need:
        apply('drSetPacket mapcar('symbolToString yhwPacket))
    The apply line calls the drSetPacket with the list members as individual arguments. Because they are symbols not strings, the mapcar transforms each argument in your lines above into a string.
  • WTony
    WTony over 7 years ago in reply to Andrew Beckett
    Thanks Andrew
