  3. Variable overflow
  • Views 16042
Variable overflow
ksek
ksek over 7 years ago
I wish to code the below equation:
nCr = (n!) / (r! * (n-r)!)
When i use the factorial function (n!)  as below:
procedure( factorial( n )
if( zerop( n ) then
1
else
n*factorial( n-1)
) ; if
) ; procedure
factorial(17) already make the data overflow. That means the max of n that i can use is only 16.
I would like to do factorial of until 5000.
Please let me know if you have any alternatives to do that.
Kean Sek.
  • mbracht
    mbracht over 7 years ago
    Hi Kean,
    the problem is that you are using (32bit) integers which are (naturally) limited in their size.
    Change your code so as it uses floats and off you go...
    (defun factorial (n)
       if( zerop( n ) then
          1.0
       else
          n*factorial( n-1)
       ) ; if
    But - a factorial of 5000 is such an incredible number that even floats won't do anymore - 170 is the last one that works, after that you get 'inf'
    (factorial 170)
    7.257416e+306
    1>
    (factorial 171)
    inf
    1>
    Just outta curiosity,- why would anybody want to compute the factorial of 5000???
    Max
  • henker
    henker over 7 years ago in reply to mbracht
    You can just unroll the factorials and reduce the formula to get the operations down to r (resp. n-r, whichever is smaller) multiplications and divisions (r-1 if you also skip the last division by 1). With this you can calculate the number of combinations with n=5000 and r<=161 (or >=4839) before reaching number overflow. For n<1030 it will not overflow for any r.
    procedure( combinations_r_outof_n( n r )
        let( (res)
            ;C(n,r) = (n!) / (r! * (n-r)!)
            ;       = Prod((n-r+1)..n) / Prod(1..r)
            cond(
                ( n<r  || n<0   nil )
                ( n==r || n<=1  1   )
                ( t
                    ; swap sides
                    when( 2*r > n
                        r = n-r
                    ); when
                    res = 1.0
                    for(x n-r+1 n
                        res = res * x / r
                        r--
                    ); for
                    when(res<2147483647  res=fix(res))
                    res
        ); let
    ); procedure
  • ksek
    ksek over 7 years ago in reply to henker
    Hi Max,
    I was doing something to count the possible combinations of 2 standard cells abutment in a pool of 5000 standard cells.
    This require me to code the equation nCr.
    Hi Henker,
    Your solution works well for me.
    Thanks so much for the simplified algorithm.
    KS.
