  3. Function to check if an object is inside an object
  • Views 16094
MSP032
MSP032 over 7 years ago
Please let me know if there's a function to check if an object is inside another object.
For instance, consider the objects, 'shape1' and 'shape2' in the below figure.
In this case, the object 'shape2' is not entirely inside the object 'shape1'.
Please let me know if there's a built-in function(or the algorithm) to find the same.
Mallikarjun
  • RK56
    RK56 over 7 years ago
    Are you aware of abe* functions? These are Advanced Boolean Functions which can handle these.
    -Ramakrishnan
  • MSP032
    MSP032 over 7 years ago in reply to RK56
    Thanks Ramakrishnan.
    I'll check them out.
    Mallikarjun
    Andrew Beckett over 7 years ago in reply to MSP032
    A simple way is to do shape2 ANDNOT shape1. You can do this with the abe functions, but also dbLayerAndNot or dbPointArrayAndNot.
  • MSP032
    MSP032 over 7 years ago in reply to Andrew Beckett
    Thanks a lot for your suggestions.
    I used the function 'dbLayerAnd' for this purpose.
    Mallikarjun
