  3. Layout cell boundary
  • Views 16443
Will Tang
Will Tang over 7 years ago
Hi all,
I'm encountering a annoying issue.
First, I place a lot of layout cells/transistors into a layout cell.
Then, after packing the cells into a smaller area, when zooming to fit all, it zooms to a big area (the original placement .... zoom out a lot).
It seems the cell still remembers the original placement of cells/transistors.
Does anyone encounter the same issue?
Any comment is much appreciated.
Thank you
Will
  • mbracht
    mbracht over 7 years ago
    Hi Will,
    I don't think this is really a SKILL question is it?
    Sounds to me like you haven't moved everything. Most likely there's shapes with their layer's visibility turned off. The 'Zoom Fit' allows for these shapes - visible or not.
    Max
