  3. mos property change using skill
  • Views 15978
iqbalsahid
iqbalsahid over 7 years ago
hi,
I want to change mos property using skill. Other property changing except "m".
I use a for loop to check prop whiin ins~>prop. if match with prop~>name prop~>value will change to new value.
but multiplicity is not changing.
using prop~>name i saw "m" property not coming.
("amsfetType" "wiringStartColorM0" "wiringOverhangM0" "wiringMarginM0" "wiringOffsetM0"
"wiringWidthPatternM0" "wiringWidthM0" "dummyRxFinBot" "dummyRxFinTop" "gateExtBotSwitch"
"gateExtTopSwitch" "floatPcL" "floatPcR" "dummyPcL" "dummyPcR"
"permuteRule" "lrsd" "p_vta" "acv_uncorr_sign" "pdevhgeos"
"pdevhgeos_sw" "pdevlgeos" "pdevlgeos_sw" "pdevdops" "pdevdops_sw"
"psej" "pdej" "asej" "adej" "cdfParamType"
"ngcon" "composite" "extract" "cpp" "fpitch"
"total_nfin" "nfin" "nf" "l" "fetType"
But in gui if i modify multiplicity of mos "m" is coming
("amsfetType" "par" "m" "wiringStartColorM0" "wiringOverhangM0"
"wiringMarginM0" "wiringOffsetM0" "wiringWidthPatternM0" "wiringWidthM0" "dummyRxFinBot"
"dummyRxFinTop" "gateExtBotSwitch" "gateExtTopSwitch" "floatPcL" "floatPcR"
"dummyPcL" "dummyPcR" "permuteRule" "lrsd" "p_vta"
"acv_uncorr_sign" "pdevhgeos" "pdevhgeos_sw" "pdevlgeos" "pdevlgeos_sw"
"pdevdops" "pdevdops_sw" "psej" "pdej" "asej"
"adej" "cdfParamType" "ngcon" "composite" "extract"
"cpp" "fpitch" "total_nfin" "nfin" "nf"
"l" "fetType"
I wat to cahnge "m" in skill code how?
    There's nothing special about m as far as the database is concerned. It's possible that a particular PDK might use a different parameter than "m", but for updating with SKILL there's nothing special needed.
    How are you updating normal parameters and the "m" parameter using SKILL? Can you give an example where it doesn't work? You've just shown the list of instance properties after making an edit on the edit properties form - it's not clear what is not working...
