  3. Speed difference between 'DC ParamAnalysis and DC Sweep
  • Views 1568
wobbert
wobbert over 7 years ago
Hi folks,
I want to perform multiple parameter sweeps over DC/OP simulations and export the data. Since I'm an intern and only have access to ADE L (due to costs), I made an Ocean script to do so (the code I am using is added below.). I works fine but takes a lot of time to run. However if you perform a DC sweep it goes quite fast. I believe the difference is that in case of a DC sweep, the simulator (Spectre) is innitialized only once and performs all the simulations consequtive while in case of a ParamAnalysis using DC simulations, the simulator is innitialised for every seperate simulation, which causes a lot of overhead. Is it possible to use a ParamAnalysis while not innitializing the simulator for every simulation point (or is it possible to run "nested" DC Sweeps via Ocean)?
Thanks a lot Slight smile
simulator( 'spectre )
design( [..])
analysis('dc ?saveOppoint t)
desVar(   "L_cas" 200n    )
desVar(   "W_cas" 5u       )
desVar(   "F_cas" 1           )
desVar(   "F" 1    )
desVar(   "L" 5u  )
desVar(   "W" 20u            )
envOption(
               'analysisOrder  list("dc")
saveOption( 'currents "all" )
temp( 27 )
paramAnalysis( 'L_cas  ?start 100n  ?stop 1u  ?lin 10 paramAnalysis( 'W  ?start 1u  ?stop 20u  ?lin 10 paramAnalysis( 'L  ?start 1u  ?stop 5u  ?lin 10 ))))
paramRun()
selectResult('dcOp)
declare(outSignals[11])
outSignals[0] = "/V0/PLUS"
outSignals[1] = "/I93/M6/D"
outSignals[2] = "/I94/M6/D"
outSignals[3] = "/I95/M6/D"
outSignals[4] = "/I96/M6/D"
outSignals[5] = "/I97/M6/D"
outSignals[6] = "/I98/M6/D"
outSignals[7] = "/I99/M6/D"
outSignals[8] = "/I100/M6/D"
outSignals[9] = "/I101/M6/D"
outSignals[10] = "/I102/M8/D"
for(outSig 0 length(outSignals)-1
               ocnPrint(?output strcat("[..]" sprintf(nil "%02d" outSig) ".dat") ?numberNotation 'scientific getData(outSignals[outSig]))
