  3. MATLAB Interface S-parameter Data Import
  • Replies 10
  • Views 20833
Curtisma
Curtisma over 7 years ago
The aaSP function in MATLAB isn't working for me at all.
I open Matlab and load my results successfully, but when I try to get some data using the aaSP function it throws an error every time as shown below.  Using the aaSP function in the Cadence calculator and as part of an expression in Maestro works great on the same results data set.
Any idea where I am going wrong?  I have tried specifying the datapoint # and test name when running the loadResult() method but it still throws an error.  I also tried specifying the result name ('sp-sp') and result directory as part of my call to aaSP but those also throw an error.
The transient data access functions (VT) do work for another sim I'm running.  I haven't been able to find a way to evaluate an expression and return a Waveform to MATLAB.  Is this possible?
I am using MATLAB R2019a and Virtuoso IC6.1.7-64b.500.23  I have also tried it with MATLAB 2018a and it works the same.
Curtis
    Hi Curtis,
    It looks as if the s-parameter data is missing (I just tried it with an s-parameter run with the same Virtuoso and Matlab versions you're using and it worked for me). Can you try:
    analyses=cds_srr(adeInfo.adeCurrentResultsPath)
    signals=cds_srr(adeInfo.adeCurrentResultsPath,'sp-sp')
    signals.S_Param
    and post what you get?
  • Curtisma
    Curtisma over 7 years ago in reply to Andrew Beckett
    Yeah, thanks Andrew!
    I just started a vacation for a week to bike RAGBRAI, but I'll try it as soon as I get back.
    - Curtis
  • Curtisma
    Hey Andrew:
    Actually, I've been able to stop into the office today.  The commands you provided are also throwing a similar error.
    -Curtis
  • Curtisma
    I've found that those commands do work if I change the results path slightly by appending "/<test name>/psf" with the test name being "FSPAR_a" in this case.
    Andrew Beckett over 7 years ago in reply to Curtisma
    Hi Curtis,
    Your initial experiment was for a single point (see adeDataPoint in adeInfo), for which the cds_srr function should work. The example today has adeDataPoint set to -1 and also doesn't have the test specified (you could solve this with adeInfo.loadResult('dataPoint',1,'test','FSPAR_a') first). So you're not comparing like with like. The cds_srr really needs the leaf level data, whereas aaSP should work at the top level (although you have to be looking at a single test at a time).
  • Curtisma
    Hey Andrew:
    Ok, so I ran the cds_srr commands after loading a single data point and they seemed to return what I would expect as shown below havever the aaSP function is still throwing an error as shown below.
    Ah, I wonder if this is something to do with having more than 9 ports. The naming convention changes when you have more than 9 ports (goes from s11 to s1:1). I'll do some checks.
    Andrew Beckett over 7 years ago in reply to Andrew Beckett
    Hi Curtis,
    Yes, that's exactly what it is. The aaSP() function assumes the signals are called "sNM" and not "sN:M". That's a bug that we need to fix. Could you log a case with support.cadence.com and then post the number here - I'll pick it up and file the CCR (it's best to be tied to a customer rather than just me doing it myself).
  • Curtisma
    Hey Andrew:
    I already had the following case open:
    Case # 46373090
    Any idea how long it would take to get an update?  I was really hoping to use this for some post-processing of spar results right away.
    Do you think I could go in and change the MATLAB code or maybe subclass and override a method in MATLAB to fix the issue in the meantime?
    -Curtis
    Hi Curtis,
    I'm checking with the case owner to see if I can pick it up. This will need an enhancement to aaSP to make it smarter. I've just written a modification to the current code, and I'll send it to you via the case.
