  3. pcellEvalFailed errors for gpdk090
  • Views 19012
Nicolas Callens
Nicolas Callens over 7 years ago
Hi everyone,
I was taking a few layout courses from Cadence: Virtuoso Layout Design Basics vIC6.1.7 and Virtuoso Connectivity-Driven Layout Transition vIC6.1.7ISR17. But I am constantly havind pcellEvalFailed errors when I am opening the layout views:
*WARNING* (DB-270001): Pcell evaluation for gpdk090/pmos2v/layout has the following error(s):
*WARNING* (DB-270002): ("eval" 41 t nil ("*Error* eval: undefined function" gpdk090_evalMtlCvg))
*WARNING* (DB-270003): Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
Does anybody know how I can solve it. I am currently using IC6.1.8 and I have downgraded the Virtuoso Suite to IC6.1.7 but nothing seems to work...
Kind regards,
Nicolas
  • mbracht
    mbracht over 7 years ago
    Obviously there are instances of PCells in the cell view you are trying to open. A PCell is in the end nothing else but a SKILL function that computes an instance's  master cell view and that SKILL function tries to call a function by the name of gpdk090_evalMtlCvg(..) which doesn't seem to exist in your environment. So the question is - why is that function missing. The function definition should come along with the libInit.il of the gpdk090.
    By the way - I can place instances of gpdk090/pmos2v/layout so there seems to be something wrong with your environment.
    regards
    Max
  • Nicolas Callens
    Nicolas Callens over 7 years ago in reply to mbracht
    Hi Max,
    I had a look into the libInit.il and indeed, I can't find the function... Kind of weird because the whole package is what I have downloaded from the Cadence iLS webpage.
    Kind regards,
    Nicolas
  • mbracht
    mbracht over 7 years ago in reply to Nicolas Callens
    Hi Nicholas,
    It doesn't necessarily need to be defined in the libInit.il directly - it might as well just got loaded from there. I think(!!) the function definition is in the context file gpdk090.cxt in the library directory.
    Max
  • Nicolas Callens
    Is it normal that I can't open that file? Even if the function definition is not there, is there way to get it?
    Nicolas
  • mbracht
    Nicolas.
    Are you saying you don't have that file? In that case you should open a support case and specify "Internet Learning Series" as product.
    Max
  • Nicolas Callens
    Yes, I have it. What I have noticed is that in the Unix terminal the following pops up when I am starting virtuoso:
    ln: target 'gpdk090.cxt' is not a directory
    No idea where it is described to make a link of this .cxt file.
    Nicolas
