  3. Is it possible to make aelEnvInterpret correctly evaluate...
  • Views 2193
Is it possible to make aelEnvInterpret correctly evaluate the expression containing "pPar/iPar"?
zssfred
zssfred over 7 years ago
Strictly speaking, AEL function is not skill function, so I put it here.
env = aelEnvCreate( 'f t t )
aelSetLineage(env tmp4) ;tmp4 is the lineage correctly retrieved
aelEnvSetGlobals(env "a" "0.1u")
aelEnvSetGlobals(env "b" "0.2u")
expression1 = "a+b"
expression2 = "pPar(\"sbn\")"
expression3 = "a+b+pPar(\"sbn\")"
In my test, if do aelEnvInterpret respectively for these three expressions, I can get correct result from expression1 and expression2. In expression3, aelEnvGetErrStr() will croak "data type error".
Any ideas?
Thanks.
Fred
    I moved this to the SKILL Forum because the aelEnv functions are SKILL. The expressions you're evaluating aren't SKILL (they're AEL) but the functions you're using to evaluate them absolutely are SKILL, so this is the right place.
    My guess is that the sbn parameter is defined in the CDF with "Parse as Number" not being set to "yes" (also "Parse as CEL" should be set to "yes"). I can certainly reproduce the error if that's the case.
  • zssfred
    zssfred over 7 years ago in reply to Andrew Beckett
    Andrew,
    I confirm it is exactly the case you described.
    Thank you so much! I have been going a so long journey(like trying to parse the expression by myself, removing pPar from CDF definition, ... etc) before find this help.
    Really appreciate!
    Thanks.
    Fred
