  3. Using SKILL to copy content between layout views
  • Views 17693
jaleco
jaleco over 7 years ago
I am using SKILL to (select and) copy layout content between Virtuoso layout views.
From previous posts, there seem to be 2 commonly recommended approaches - (1) using dbCopyFig(), and (2) dbCreateInst() followed by dbFlattenInst().
I would like to use both in different situations, but whereas dbCopyFig() will capture selected prBoundaries, they are not retained by the flattening functions dbFlattenInst() and leFlattenInst().
How to retain a cell boundary when removing hierarchy / using the flatten operations?
    You can use dbFlattenInst2 as this has an option called mergePRBoundary (it can't just preserve it, because you may have an existing prBoundary, and you can only have one - so it offers the choice of merging them).
  • jaleco
    jaleco over 7 years ago in reply to Andrew Beckett
    Thanks Andrew!
    This did not work if , as in my case, a prBoundary object did not exist in the destination cell view.
    Apparently the merge option cannot merge the source prBoundary with a non-existent destination cell prBoundary.
    However, based on your feedback, I realized there were multiple descriptions of the dbFlattenInst functions found in the Cadence Help browser.
    The ones I had been looking at in the Virtuoso Shared Tools/.../CDBA Figure Functions/Instance Creation and Modification section do not include a description of the mergePRBoundary option.
    So it was very hlepful to realize I needed to be looking in the SKILL/Virtuoso Design Environment SKILL Reference/Cellview InputOutput Database Access Functions section!!
    I'm working around this by grabbing the prBoundary of the source cellview after the flatten function removes it:
    dbFlattenInst(new_inst 1)
    if(cv_src~>prBoundary then dbCopyFig(cv_src~>prBoundary cv_dest))
    Thanks again very much for your feedback!
