  3. Modgen Topology Constraints
  • Subscribers 150
  • Views 16335
Vishu21
Vishu21 over 7 years ago
Cadence Virtuoso version- ICADV12.3-64b.500.18
In the help section find the term "Modgen Topology Constraints"
There you see a list of different Constraints, Go inside 'Via control' , in the example given for via control Constraint they have defined in the following manner if you see..
list ("viaControl" nil 1
            list(stringToSymbol "viaControlOrient" Horizontal)
            list(stringToSymbol "viaControlInline" t)
            list(stringToSymbol "viaControlOffset" t)
I am using the same list in my script but getting an error as "unbound variable stringToSymbol"
which is obvious as stringToSymbol is a function which requires a string as a parameter....
So i am not getting where i need to change the sytax !!!
Andrew please clarify!!
Vishal
  • Vishu21
    Hi Andrew ,
    I guess this post hasn't reached to you, so i am replying to this thread.
    Kindly go through this and suggest me something.
    Vishal.
  • henker
    henker over 7 years ago
    You are not calling the stringToSymbol function; e.g. the code piece "list(stringToSymbol "viaControlOffset" t)" calls the list function to create a list consisting of three elements: stringToSymbol (given as variable), "viaControlOffset" (given as string), and t (given as symbol).
    To call a function use either lisp style, e.g. (stringToSymbol "viaControlOffset") or C style, e.g. stringToSymbol( "viaControlOffset")
    Note, that in C style the opening parenthesis must directly follow the function name.
    Andrew Beckett over 7 years ago in reply to Vishu21
    Vishal,
    if this was urgent, you should have contacted customer support.
    I respond to questions here during spare time, and it is not part of my job at Cadence to answer questions on the forums As a result, when I am busy or on vacation I cannot always respond, even to something as simple as this question. There are also a few other Cadence folks that respond from time to time (as themselves), but they also get busy too.
    Thanks to henker for replying below. That’s what the community is supposed to do - it’s not just me that has to answer.
  • Vishu21
    Vishu21 over 7 years ago in reply to Andrew Beckett
    I totally understand.
    Thanks for your response.
    Vishal.
  • Vishu21
    Vishu21 over 7 years ago in reply to henker
    Hi henker,
    Thanks for answering.
    Vishal.
