  3. What am i doing wrong in the script (for form with grids...
  • Views 16849
What am i doing wrong in the script (for form with grids)?
ssram
ssram over 7 years ago
Hello...
I'm creating a form with different tabs and in one of the tabs, i'm trying to add a Browse button using ddsFileBrowseCB to browse a file and display that in a stringField.
But unfortunately i'm having a trouble doing it and it says
ddsFileBrowseCB( hiGetCurrentForm() 'filename)
*WARNING* ddsFileBrowseCB: Invalid target string field: filename; not found on the form.
And my code for that particular grid is:
CellListField = hiCreateGridLayout( 'CellListField ;?frame "Select the cell-list"
?items list(
;list( hiCreateLabel( ?name 'CellListFieldName ?labelText "Cell-list : " ) 'row 1 'col 0 )
list( hiCreateStringField(
?name 'filename
?prompt "Cell-list : "
?value CellListFieldValue
?defValue "celllist"
?editable t) 'row 1 'col 1)
list( hiCreateFormButton(
?name 'browseBtn
?buttonText "Browse..."
?callback "ddsFileBrowseCB( hiGetCurrentForm() 'filename)") 'row 2 'col 1)
;list( 'col_stretch 1 1 )
Could someone help me fix this issue?
SSR
  • mbracht
    mbracht over 7 years ago
    I just tried your code and I'am not getting this error. All I did was changing "?value CellListFieldValue" to a literal string (?value "whatever") because that variable didn't exist for me. I also had to create a Layout form to contain the Grid layout and then display it. So maybe it'd be helpfull if you provide a complete testcase that reproduces the error.
    Max
  • ssram
    ssram over 7 years ago in reply to mbracht
    Pasting here the whole form script that i'm using. Please let me know if i'm doing something stupid in it.
    procedure(srDrcLvsForm()
    if(boundp('srFindLibNameValue) == nil then
    srFindLibNameValue = ""
    );end if
    if(boundp('CellListFieldValue) == nil then
    CellListFieldValue = ""
    );end if
    if(boundp('DrcRunModeValue) == nil then
    DrcRunModeValue = ""
    );end if
    ;if(boundp('DrcOptionsValue) == nil then
    ; DrcOptionsValue = "t nil t nil nil"
    ;);end if
    if(boundp('LvsOptionsValue) == nil then
    LvsOptionsValue = ""
    );end if
    srFindLibName = hiCreateGridLayout( 'srFindLibName ;?frame "Library"
    ?items list(
    ;list( hiCreateLabel( ?name 'srFindLibNa ?labelText "Library : " ) 'row 0 'col 0 )
    list( ddHiCreateLibraryComboField(
    ?name 'libraryName
    ?prompt "Library : "
    ?value srFindLibNameValue
    ?defValue ""
    ?callback "ddsUpdateSyncWithForm()") 'row 0 'col 1)
    ?items list(
    ?name 'filename
    ?name 'browseBtn
    RunDrcYesNo = hiCreateGridLayout( 'RunDrcYesNo ;?frame "Select if you want to run DRC"
    ?items list(
    list( hiCreateLabel( ?name 'drcRunYNLabel ?labelText "Run DRC (Y/N) ? : " ) 'row 0 'col 0 )
    list( hiCreateRadioField(
    ?name 'drcRunYN
    ?value ""
    ?defValue "No"
    ?choices list("Yes" "No")) 'row 0 'col 1)
    DrcRunMode = hiCreateGridLayout( 'DrcRunMode ?frame "Select the DRC run mode"
    ?items list(
    ;list( hiCreateLabel( ?name 'DrcModeLabel ?labelText "Mode : " ) 'row 3 'col 0 )
    ?name 'runMode
    ?value DrcRunModeValue
    ?defValue "flat"
    ?choices list("flat" "hier")) 'row 3 'col 1)
    DrcOptions = hiCreateGridLayout( 'DrcOptions ?frame "Select the DRC options"
    ?items list(
    list( hiCreateToggleField(
    ?name 'DrcOpt
    ;?value DrcOptionsValue
    ;?defValue 'Base
    ?choices list(list('Base) list('BaseDensity) list('Metal) list('MetalDensity) list('FloatingMetal))) 'row 4 'col 1)
    RunLvsYesNo = hiCreateGridLayout( 'RunLvsYesNo ;?frame "Select if you want to run LVS"
    ?items list(
    list( hiCreateLabel( ?name 'lvsRunYNLabel ?labelText "Run LVS (Y/N) ? : " ) 'row 0 'col 0 )
    ?name 'lvsRunYN
    ?value ""
    ?defValue "No"
    LvsOptions = hiCreateGridLayout( 'LvsOptions ?frame "Select the Connection Options"
    ?items list(
    ;list( hiCreateLabel( ?name 'LvsOptionsLabel ?labelText "Mode : " ) 'row 1 'col 0 )
    ?name 'LvsOpt
    ?value LvsOptionsValue
    ?defValue "Physical"
    ?choices list("Physical" "Virtual")) 'row 1 'col 1)
    TriggerEmail = hiCreateGridLayout( 'TriggerEmail ;?frame "Make the selection for Email after each verification"
    ?items list(
    list( hiCreateLabel( ?name 'triggerEmailLabel ?labelText "Trigger Email (Y/N) ? : " ) 'row 4 'col 0 )
    ?name 'triggerEmailYN
    ?value ""
    ?defValue "Yes"
    ?choices list("Yes" "No")) 'row 4 'col 1)
    ;LvsOptions = hiCreateCyclicField(
    ; ?name 'LvsOptions
    ; ?prompt "Connection Options : "
    ; ?choices list( "Physical" "Virtual" )
    ; ?value "Physical"
    ; ?defValue "Physical"
    srTabField = hiCreateTabField(
    ?name 'srTabField
    ?tabs '("Lib-Cell" "DRC" "LVS")
    ?tabPlacement 'top
    ?fields list(
    list(hiCreateFormLayout('page1 ?items list(srFindLibName CellListField) ))
    list(hiCreateFormLayout('page2 ?items list(RunDrcYesNo DrcOptions DrcRunMode TriggerEmail) ))
    list(hiCreateFormLayout('page3 ?items list(RunLvsYesNo LvsOptions TriggerEmail) ))
    layout = hiCreateFormLayout(
    'MyFormLayout
    ?items list( srTabField )
    DrcLvsForm = hiCreateLayoutForm(
    'DrcLvsForm "Multi-Cell DRC/LVS" layout
    ?unmapAfterCB nil
    ?initialSize '(502 360)
    ?callback "srPerlFileWrite() srRunDrcLvs()"
    ?buttonLayout 'OKCancelDef
    DrcLvsForm->srTabField->value=1 ;; This makes the first page as default when the form appears first time
    DrcLvsForm->srTabField->defValue=1 ;; This makes the first page as default when defaults button is clicked
    DrcLvsForm~>srTabField~>page2~>DrcOpt~>Base~>value = t ; This turns on the Base check for the first time
    DrcLvsForm~>srTabField~>page2~>DrcOpt~>Metal~>value = t ; This turns on the Metal check for the first time
    RunDrcYesNoValue = DrcLvsForm~>srTabField~>page2~>drcRunYN~>value
    DrcRunModeValue = DrcLvsForm~>srTabField~>page2~>runMode~>value
    DrcOptionsValue = DrcLvsForm~>srTabField~>page2~>DrcOpt~>value
    RunLvsYesNoValue = DrcLvsForm~>srTabField~>page3~>lvsRunYN~>value
    LvsOptionsValue = DrcLvsForm~>srTabField~>page3~>LvsOpt~>value
    TriggerEmailValue = DrcLvsForm~>srTabField~>page2~>triggerEmailYN~>value
    srFindLibNameValue = DrcLvsForm~>srTabField~>page1~>libraryName~>value
    CellListFieldValue = DrcLvsForm~>srTabField~>page1~>filename~>value
    hiInstantiateForm( DrcLvsForm )
    hiDisplayForm( DrcLvsForm )
    );procedure
  • henker
    henker over 7 years ago in reply to ssram
    You are instanciating the the controls inside a tabview, thus the filename stringfield (which is the target of the file browser) is child of the tabview page, not of the form.
    Should be fixed by
    ?callback "ddsFileBrowseCB( hiGetCurrentForm()->srTabField->page1 'filename)")
  • ssram
    ssram over 7 years ago in reply to henker
    Thank you, this works!
