  3. Accessing the properties of a Via (ie. enclosures) in ~...
  • Views 17346
Accessing the properties of a Via (ie. enclosures) in ~SKILL
alexcb
alexcb over 7 years ago
I'm working in version ICADV12.3-64b.500.21 of Virtuoso.
I am currently writing a SKILL program that changes the value layer2Enc of a via, but retains its layer1Enc. In order to do this, I create a new via with a corresponding property list (association list) containing properties such as layer1Enc, cutWidth, etc. If I would like to retain the layer 1 enclosure of the via that I intend to replace, where would I find this enclosure?
I've tried:
via~>viaHeader~>overrideParams
But the parameters specified within overrideParams differ from what appears in the GUI form, "Edit Via Properties".
I've also tried:
via~>viaHeader~>viaDef~>params
This also contradicts the data I'm getting from Edit Via Properties. I'm relatively new to SKILL, so I first assumed that there would be a CDF description associated with an instantiated via. But I am unable to retrieve any cdf description, partially because vias aren't created as instances and defined within a tech database.
How could I find a Via's layer1Enc using SKILL?
Alex
    Andrew Beckett over 7 years ago +1
    Hi Alex, To retrieve the layer1Enc (or layer2Enc) of a via you can directly look this up on the instance of the via (it actually is really stored in the viaHeader or in the defaults, but there's a convenient…
    Hi Alex,
    To retrieve the layer1Enc (or layer2Enc) of a via you can directly look this up on the instance of the via (it actually is really stored in the viaHeader or in the defaults, but there's a convenient method to find the info):
    via~>layer1Enc
    You can even set it this way too:
    via~>layer1Enc=list(0.2 0.3)
    The same thing can be done with cutRows, cutColumns, cutSpacing etc. In essence changing these parameters will cause a new viaHeader to be created and for the via to be remastered using that new viaHeader. There's no need to recreate the via to change its parameters (the only case you really need to do that is if you create a different type of via).
  • alexcb
    alexcb over 7 years ago in reply to Andrew Beckett
    Great. Thanks a lot, Andrew!
