  3. How to disable/enable a device in schematic pcell while...
  • Views 6809
How to disable/enable a device in schematic pcell while netlisting
kalikrishna
kalikrishna over 7 years ago
I've created a schematic parameterized cell (Pcell) in which I've 3 types of capacitors (MOS, MIM and MOM caps). When I insatiate this cell in a top cell, I want to have a switch for each of these caps, so that I can disable/enable them in the top cell based on my requirement. Let's say in one case, I want to netlist MOS and MIM only. And in another case, I want to netlist MIM and MOM.
I came to know that there is an option called nlAction. If I add this as netset, CDL export is ignoring the particular cap while netlisting. This is working fine for the current schematic. But I want this to be parameterized, so that I can toggle net listing of each cap from top cell.
Could someone help me with this.
Prasad
    Hi Prasad,
    If you have a PCell, please share the PCell SKILL code - all you should have to do in your code is add the nlAction=ignore to each instance or not based on the parameter for the PCell.
    However, from reading what you said, I suspect  you haven't got a PCell at all, but a normal schematic that just happens to pass parameters through the hierarchy. You are also talking about netsets which is a specific type of property for setting inherited connection parameters, so you have some rather strange terminology being used here (so that's why I suspect you didn't mean PCell, and  you didn't mean netset).
    If you are expecting to have a normal schematic, and then be able to pass a parameter which selects which to pass nlAction=ignore to, then you can't do that, You could instead create a config, and then in the tree view select the two instances you don't want to netlist and set these to "bind to open".
  • kalikrishna
    kalikrishna over 7 years ago in reply to Andrew Beckett
    Thanks for your reply. Yes, I've created a normal schematic and passing variables through hierarchy using CDF parameters (I'm referring this as a PCell, as I'm able to pass variables).
    I've never created a PCell using SKILL code. Currently I've a PCell layout which I've created through PCell interactive window in layout. I'm able to control the usage of particular Cap by using "Conditional Inclusion". I need something similar in schematic as well.
    If it can't be done with a normal schematic, could you please help me with the PCell SKILL code. I can modify the SKILL code based on my requirement.
    Prasad
    Andrew Beckett over 7 years ago in reply to kalikrishna
    Hi Prasad,
    OK, so you don't have a PCell for the schematic (it's best not to use this terminology for a schematic where you are passing variables using pPar, as that is not what is normally referred to as a "PCell"). A PCell is something where you specify parameters on the instance, and a variant layout, schematic or symbol is built by calling some code (when you use the layout pcell editor, this is a primitive tool for building SKILL PCells). There is a more advanced capability called "Cadence PCell Designer" but I doubt whether you have that product.
    For schematic PCells, search in this forum for "pcDefinePCell schematic" and you'll find a few examples (albeit with issues, but with explanations on how to fix the issues).
    Here's an example of a series connected resistor schematic pcell:
    /* respcell.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 07, 2014
    Modified
    By
    Example of a series resistor pcell.
    Original version only contained connectivity - this one contains "graphics"
    too so that if you descend into the schematic you can probe nets.
    SCCS Info: @(#) respcell.il 04/07/14.11:02:22 1.2
    procedure(abCreateResPcell(libName cellName)
      let( (pcellId)
        unless( ddGetObj(libName)
          error("Couldn't open library %L" libName)
        pcellId =  pcDefinePCell(
          list( ddGetObj(libName) cellName "schematic" "schematic" )
          ; Default Parameters
    	(ns "1")
          let(( pcCV masterCv instName instId netP netM numInsts y (resHeight 0.375)
    	(wireLen 0.125) pinMaster pinFig wire lastCoord)
    	pcCV = pcCellView
    	; open master cellviews
    	masterCv = dbOpenCellViewByType( "analogLib" "res" "symbol" nil "r" )
    	pinMaster=dbOpenCellViewByType("basic" "iopin" "symbol")
    	numInsts=atoi(ns)
    	when(numInsts<1 numInsts=1)
    	; Create nets and terminals
    	netP=dbMakeNet(pcCV "PLUS")
    	netM=dbMakeNet(pcCV "MINUS")
    	dbCreateTerm(netP "PLUS" "inputOutput")
    	dbCreateTerm(netM "MINUS" "inputOutput")
    	y=0
    	pinFig=dbCreateInst(pcCV pinMaster "" 0:y "R0")
    	dbCreatePin(netP pinFig)
    	lastCoord=0:y
    	for(inst 1 numInsts
    	  ; Create the nets connected to either side
    	  if(inst==1 then
    	  else
    	    netP=dbMakeNet(pcCV sprintf(nil "net%d" inst-1))
    	  ) ; if
    	  if(inst==numInsts then
    	  else
    	    netM=dbMakeNet(pcCV sprintf(nil "net%d" inst))
    	  sprintf(instName "R%d" inst)
    	  y=y-wireLen
    	  instId = dbCreateInst( pcCV masterCv instName (0:y) "R0" )
    	  dbCreateProp(instId "r" "string" "pPar(\"r\")/pPar(\"ns\")")
    	  ; Connect up the instance
    	  dbCreateInstTerm(netP instId dbFindTermByName(masterCv "PLUS"))
    	  dbCreateInstTerm(netM instId dbFindTermByName(masterCv "MINUS"))
    	  wire=dbCreateLine(pcCV list("wire" "drawing") list(lastCoord 0:y))
    	  dbAddFigToNet(wire netP)
    	  y=y-resHeight
    	  lastCoord=0:y
    	y=y-wireLen
    	dbCreatePin(netM pinFig)
    	dbAddFigToNet(wire netM)
    	dbSetConnCurrent(pcCV)
    	dbClose( masterCv )
    	;; Always return true
    	t
          ) ; ** let **
        ; not sure if below is really necessary
        dbSave(pcellId)
        dbClose( pcellId )
      ) ; ** let **
  • kalikrishna
    Thank you so much for the Example script to create a schematic Pcell. It really helped me to create a PCELL for capacitors
    Prasad
