  3. Issues with spacebar as bindkey
  • Views 15180
Clint Meyer
Clint Meyer over 7 years ago
Hello
I am trying to apply the following bindkey
hiSetBindKey("Layout" "<Key>space" "mouseApplyOrFinishPoint()")
hiSetBindKey("Layout" "<Key>space EF" "")
This works wonderfully until I create a wire......the spacebar bindkey is overwritten to add via and no longer works as "mouseApplyOrFinishPoint()" in other commands.
I am using IC6.1.7-64b.500.22
Thanks for any insight.
Clint
  • Clint Meyer
    I solved this issue.  I had a mistake in the enterFunction bindkey.  Although I don't understand why after I executed the wire command that the space bindkey was overwritten.
    Proper bindkey
    hiSetBindKey("Layout" "<Key>space EF" "mouseApplyOrFinishPoint()")
