  3. Is there any way to forcing update for layout environment...
  • Views 15129
Is there any way to forcing update for layout environment value?
iDave
iDave over 7 years ago
when we use envSetVal to change a value for  layout cell view, such as enableDimming , the current layout won’t update display result.  But when we reopen this layout , the display is changed.  So is there have any command to forcing update the tool environment value?
Regards
Dave
    Hi Dave,
    I assume you mean the cdsenv:
    layout dimmingOn boolean t
    which you can set with:
    envSetVal("layout" "dimmingOn" 'boolean t)
    In general, changing it for the current window is done by setting the same property on the window:
    hiGetCurrentWindow()->dimmingOn=t
  • iDave
    iDave over 7 years ago in reply to Andrew Beckett
    hiGetCurrentWindow()->dimmingOn=t is what I want.
    Thank you.
    Dave
