  3. Change default "analogLib" => "cap" CDF auCdl netlist modelName...
  • Views 3967
Change default "analogLib" => "cap" CDF auCdl netlist modelName "CP" at schematic instance level with on-disk persistence from SKILL
Luca Pacher
Luca Pacher over 7 years ago
For an analog-on-top top-level signoff LVS I need to have a few dummy capacitors from analogLib instantiated in the top-level schematic of my design to match full-chip LVS. From the top-level schematic in Virtuoso I generate a CDL netlist with the si netlister to be compared with a CDL netlist generated by a third party layout extraction tool.
The final LVS doesn't match only because those dummy capacitors by default are netlisted by si with their default "CP" modelName as registered in CDF simInfo~>auCdl property list, while the mapping file from the foundry maps those dummy extra capacitors into capacitors from analogLib with modelName "CM" causing mismatch errors between layout and schematic.
If I edit by hand the CDL netlist generated by si by replacing all "CP" occurrences with "CM" the LVS is clean. Indeed, I would prefer to have si to netlist my schematic and export dummy capacitors with modelName "CM" as requested.
There are a lot of documentation on Cadence Online Suppor and SKILL examples about CDF and auCdl starting from
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXDrEAM&pageName=ArticleContent&oMenu=People%20who%20viewed%20this%20also%20viewed
but for me it's definitely not clear if I can modify with on-disk persistence the CDF  simInfo~>auCdl properties at the instance level without the need of making a local copy of the component from analogLib and override CDFs in the base-layer on that copy as described in
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVoxEAE&pageName=ArticleContent
I tried to write a simple SKILL script that opens the top-level schematic view that I want to netlist, loops over all instances, gets CDFs if the instance is a cap from analogLib and tries to override modelName in the simInfo~>auCdl section but it doesn't work :
cv = dbOpenCellViewByType("myLibName" "myCellName" "schematic" nil "a")
foreach(instPtr cv~>instances
   ;; process ONLY dummy capacitors
   if(instPtr~>libName == "analogLib" && instPtr~>cellName == "cap"
   then
      printf("Updating CDF for cell name: %s\n" instPtr~>cellName)
      instCdfPtr = cdfGetInstCDF(instPtr)
      putpropq(
         getq(instCdfPtr simInfo) '( nil
            netlistProcedure   ansCdlCompPrim
            instParameters     (C)
            componentName      cap
            termOrder          (PLUS MINUS)
            propMapping        (nil C c)
            namePrefix         "C"
            modelName          "CM"  => this value by default is "CP" and I want it to become "CM" for all dummy capacitors from analogLib in my schematic view
         auCdl
      cdfSaveCDF(instCdfPtr)  => this fails with " *WARNING* Invalid CDF data type - instData"
      cdfRefreshCDF(cv)       => this fails because cv is not a ddObj pointer
   )   ;; if
)   ;; foreach
schCheck(cv)
dbSave(cv)
dbClose(cv)
Thanks in advance, any hint or suggestion will be more than appreciated
Regards
Luca
  • RiadKaced
    RiadKaced over 7 years ago
    1. *WARNING* Invalid CDF data type - instData. You are getting this error because you can save only base-level CDF descriptions. You cannot pass an instance CDF to the cdfSaveCDF() function. The warning is a bit obscure as it fails you on the data Type. In fact, cdfSaveCDF() expects an argument of type g_cdfDataId, however an instance CDF returns an object of type instData, you cam run: instCdfPtr~>type, this will return "instData".
    You have 2 alternatives to work around this:
    1. Work at "User Cell CDF", All the changes are made at user and effective CDF level and are stored into the memory. The user-level CDF is a user-specific overlay description on top of the base-level CDF for a cell. The effective-level CDF is an overlay of a user-level CDF description on top of a corresponding base-level CDF description. This will be a much faster solution than iterating on instances of aa given design, you don't need write permissions on the design as well. the issue is you lose everything when you close virtuoso.
    2. Working at Effective CDF level for signoff purposes is dangerous bacause you cannot reproduce your results in a regression system unless you load/run the SKILL code that updates the CDF at start. A better and more reliable solution isfor you to copy the analogLib/cap cell into a project library, update the base CDF and use this cell accross your project. This is a very common practice in most design teams
    Riad.
