  3. Skill to split a string with \t
  • Subscribers 150
  • Views 21397
Amos001
Amos001 over 7 years ago
I had below kinds of text file and tried to use skill to read this text file
143 95 47 46 94 142
141 93 45 44 92 140
139 91 43 42 90 138
137 89 41 40 88 136
135 87 39 38 86 134
Skil file to read text file
let((inPort nextLine)
inPort= infile("./instlist")
when(inPort
while(gets(nextLine inPort)
println(nextLine)
);while
close(inPort)
);when
);let
The CIW result is shown as below
"143\t95\t47\t46\t94\t142\n"
"141\t93\t45\t44\t92\t140\n"
"139\t91\t43\t42\t90\t138\n"
"137\t89\t41\t40\t88\t136\n"
"135\t87\t39\t38\t86\t134\n"
How can I get 143 95 47 46 without \t or \n?
Many thanks and appreciate for your help.
  • mschw
    mschw over 7 years ago
    you could split the lines with the command parseString, e.g.
     when(inPort
        foreach(elem parseString(nextLine "\t\n")
         println(elem)
       );while
       close(inPort)
       );when
    );let
    will print all individual elements of the file one by one in the CIW.
    Kind regards
    Matthias
  • RiadKaced
    RiadKaced over 7 years ago
    The easiest way to cleanup your input line using the parseString() function mentioned by Matthias, ths function will be a list of strings split on blank characters by default. Rebuild back the string from the list with buildString(). I have created the following SKILL snippet as a solution, I'm also providing the code below for your convenience.
    ; Procedure to print the content of the file
    procedure(printFileContent(inputFile)
        inPort= infile(inputFile)
        when(inPort
            ; Cleanup the line. parseString will split all blank chacaters
            ; including \s \t \n ...etc.
            nextLine = buildString(parseString(nextLine))
            printf("%s\n" nextLine)
          );while
          close(inPort)
        );when
      );let
    ; Run the procedure after loading the file
    printFileContent("./instlist")
    Riad
  • Amos001
    Amos001 over 7 years ago in reply to RiadKaced
    Matthias and Riad,
    Appreciate for your help, many thanks.
    Amos
