  3. How can I close the form using skill code
  • Subscribers 150
  • Views 17853
raj31789
raj31789 over 7 years ago
Hi
I am very new to this forum please correct me if anything i am wrong
How can i close the form automatically without click ok using skill code,that means hiFormDone() is not working for me  when i am loading my skill file.
 Raja
  • Vishu21
    Vishu21 over 7 years ago
    Hi Raja,
    What do you mean "it's not working" ?
    Is it throwing any error?
    When you use hiFormFinish() or hiFormDone() in the script, then while the form is displayed,it will be unmapped according to argument ?unmapAfterCB of hiCreateAppForm() and if the form is not currently displayed then hiFormApply() will be executed.
    Vishal
  • raj31789
    raj31789 over 7 years ago in reply to Vishu21
    Hi Vishu
    Thansks for your reply.
            yes you are right what i exactly want is once opened the forum then automatically close the forum using skill code instead of , enter ok manually.
  • Vishu21
    Vishu21 over 7 years ago in reply to raj31789
    Hi Raja,
    What I have observed is that if you use this function hiFormDone() or hiFormFinish() directly in your script then it won't wait for the users to input the values(if form is created for taking some inputs) and will immediately close the form as soon as you run script so you need to either give some condition to invoke these functions
    One possible solution can be the use of hiRegTimer() function.
    For example write this command at the end of your script,
    hiRegTimer("hiFormDone (form_handle)"  30)
    The time is in tenth of seconds,it will wait untill that and then closes the form,I don't know if this solution fits your scenario!!
    Vishal.
