  3. Hierarchy Tree Output to a file
  • Views 19385
LakshmanQual
LakshmanQual over 7 years ago
Hi all,
I am trying to send a tree output to a file with the below code with the default option 'Current to stop level'.
But i am seeing the GUI asking for the hierarchy options 'Current to stop level' or 'Top to Current' or 'Top to Stop level'.
I want to print them with default option 'Current to stop level' without any GUI in between.
If i run the below code, I am seeing my given input file with blank and Tree output even i cancel the GUI.
Could anyone please help me in sending the output to the file mentioned?
procedure(TreeOut(@key (cv geGetEditCellView()) fileName)
if(stringp(fileName) then
port=outfile(fileName)
else
port=poport
leHiTree()
leTreeForm->treeOption->value="Current to stop level"
fprintf(port "%L\n" hiFormDone(leTreeForm))
when(stringp(fileName)
close(port)
view("./TreeOuput.txt")
hiSetBindKey("Layout" "Ctrl Shift <key> v" "TreeOut(?fileName \"./TreeOutput.txt\")")
  • RiadKaced
    RiadKaced over 7 years ago +1
    Hi Lakshman, I would recommend using SKILL CCSschTree(), it is available here . You can run the function from the CIW as follows: ;; First of all load the code in CIW: load("CCSschTree.il") ;; For…
    Andrew Beckett over 7 years ago in reply to LakshmanQual +1
    You have to download it from the link that Riad provided (I wrote the SKILL code...). There's an equivalent code (called abSchTree - I tended to rename the functions to follow the "Cadence Customer Support…
  • RiadKaced
    Hi Lakshman,
    I would recommend using SKILL CCSschTree(), it is available here. You can run the function from the CIW as follows:
    ;; For printing schematic hierarchy of top cell of library ether type in CIW:
    schcv=dbOpenCellViewByType("ether" "top" "schematic" "schematic" "r")
    CCSschTree(?cellView schcv ?port op=outfile("top_sch.txt"))
    close(op)
    ;; For printing layout hierarchy of top cell of library ether type in CIW:
    laycv=dbOpenCellViewByType("ether" "top" "layout" "maskLayout" "r")
    dbOpenHier(laycv 32)
    CCSschTree(?cellView laycv ?useViewSwitching nil ?port op=outfile("top_lay.txt"))
    close(op)
  • LakshmanQual
    LakshmanQual over 7 years ago in reply to RiadKaced
    Hi RiadKaced,
    The mentioned "CCSschTree.il" code should be copied local and run the further commands or can i find that file from any cadence built in paths??
    You have to download it from the link that Riad provided (I wrote the SKILL code...). There's an equivalent code (called abSchTree - I tended to rename the functions to follow the "Cadence Customer Support" prefix convention in the past) in this post.
