  3. Disabling cyclic field based on the radio field input in...
  • Views 15589
Disabling cyclic field based on the radio field input in a form
ssram
ssram over 7 years ago
I've the following code where i'm trying to get the values of
srMfgGridForm~>useMfgGridYN~>value
srMfgGridForm~>UserGridOptions~>value
through a form. The form has got a radio field (with "Yes" & "No") and a cyclic field. How can i disable the cyclic field when "Yes" is selected by the user on the radio field?
Ram
procedure(srFixOffGridForm()
UseMfgGridYesNo = hiCreateGridLayout( 'UseMfgGridYesNo ;?frame "Select either one of the grids below"
?items list(
list( hiCreateLabel( ?name 'useMfgGridYNLabel ?labelText "Use Manufacturing Grid (Y/N) ? : " ) 'row 1 'col 0 )
list( hiCreateRadioField(
?name 'useMfgGridYN
?value ""
?defValue "Yes"
?choices list("Yes" "No")) 'row 1 'col 1)
list( 'col_stretch 1 1 )
UserGridOptions = hiCreateCyclicField(
?name 'UserGridOptions
?prompt "Custom Grid Options : "
?choices list( "" "0.01" "0.001" "0.0001" "0.00025" "0.005" "0.0005" )
?value ""
?defValue ""
?enabled t
?invisible nil
srMfgGridField = hiCreateFormLayout('page1 ?items list(UseMfgGridYesNo UserGridOptions) )
layout = hiCreateFormLayout(
'MyFormGridFix
?items list( srMfgGridField )
srMfgGridForm = hiCreateLayoutForm(
'srMfgGridForm "Fix Off Grid" layout
?unmapAfterCB nil
?initialSize '(100 100)
?callback "srFixOffGrid()"
?buttonLayout 'OKCancelDef
UseMfgGridYesNoValue = srMfgGridForm~>useMfgGridYN~>value
UserGridOptionsValue = srMfgGridForm~>UserGridOptions~>value
hiInstantiateForm( srMfgGridForm )
hiDisplayForm( srMfgGridForm )
);procedure
  • skillUser
    skillUser over 7 years ago +1
    Hi, Add a callback function like this: procedure(srMfgGridRadioCB(field form value) if(value=="Yes" putpropq(getq(form UserGridOptions) nil enabled) putpropq(getq(form UserGridOptions) t enabled…
  • skillUser
      if(value=="Yes"
        putpropq(getq(form UserGridOptions) t enabled)
    And also change the field definition to use it (and also make the default state of the other field match the default state of this field):
    ?items list(
    ?name 'useMfgGridYN
    ?value ""
    ?defValue "Yes"
    ?callback list('srMfgGridRadioCB)
    ?value ""
    ?defValue ""
    ?enabled nil
    ?invisible nil
    Hopefully this is what you want to do.
    Best regards,
    Lawrence.
  • ssram
    ssram over 7 years ago in reply to skillUser
    Thanks Lawrence, this works.
