  3. adding newline character within a label
  • Views 18474
MalcolmWhite
MalcolmWhite over 7 years ago
I'm searching for a way to edit a label using the properties menu and adding a newline character within the label string so the label wraps
in the middle somewhere and becomes usable when width is small.
Obviously a layout person could just make two labels and edit the label height so it fits in a certain width, but instead I want to use just one label
For example if I have a label in my layout view which is "this_layout_cell_is_a_copy_of_layout_from_ReferenceLibrary_but_well_removed"
this long of a string may not fit in my layout cell width may overhang the edges by quite a bit.
There used to be a way to insert (I think it was an ascii character for newline ) a escape character and then extended command characters .
I cannot find the reference for that anymore.
What I would like would be a string I can place in layout like : "this_layout_cell_is_a_copy_of_layout\n _from_ReferenceLibrary_but_well_removed"
the \n character placed in the middle would create one label that looks like  :
Thank you for your time.
  • MalcolmWhite
    nevermind Cadence - I figured it out - you can't create the label with the ordinary label tool under Create,  you can't enter carraige return with the property edit menu , you have to create the label with the dbCreateLabel() and while you enter the 4th parameter, the interpreter will take a \n in the middle of the string and wrap the text.   this one created what I needed.  dbCreateLabel(geGetEditCellView() list("text" "drawing" ) 31.0:38.0 "really_Long\n_Label_Test" "centerCenter" "R0" "roman" 1.0)
  • dmay
    dmay over 7 years ago in reply to MalcolmWhite
    Be aware that exporting with Oasis (not stream) will not like those trailing whitespaces and carriage returns.
    Derek
    Andrew Beckett over 7 years ago in reply to dmay
    Hi Derek,
    That was a limitation at one point, but fixed (as far as I can see) in IC616 ISR3. Trailing spaces aren't a problem anyway I believe, but the carriage returns aren't allowed in OASIS, so now what happens is you get this in the log file:
    WARNING (XOASIS-81084): Input text "albert?george?" has symbols with ASCII codes: 0xA, 0xA, which are not supported by OASIS and therefore substituted by '_'. The modified text "albert_george_" will be translated to OASIS layer 7 and OASIS data type 0.
