  3. geGetSelSet() not worked on softblock's shape
  • Views 2668
Amos001
Amos001 over 7 years ago
There is a top block layout and a sub-block(softMacro) was placed inside the softMacro, after that, a pin belongs to sub-block was selected in top block layout level, and I tried to use geGetSelSet(), but the return value is nil? Is there any other function that I can use to report selected pin information?
Many Thanks
Amos
    Hi Amos,
    Use geGetObjectSelectedSet() instead. You need something that can return hierarchical objects. There is also hsmGetSelectedSet() but that doesn't return the actual objects, but instead a description of what is selected.
  • Amos001
    Amos001 over 7 years ago in reply to Andrew Beckett
    Andrew,
    Thank you for your help, it worked.
    Best Regards
    Amos
