  3. schCheck(cv) warnings and errors after updating CDF par...
  • Replies 11
  • Views 8822
schCheck(cv) warnings and errors after updating CDF params
abhi10
abhi10 over 7 years ago
Hi all,
I am trying to port schematics from one technology to another, and I edit certain transistor parameters ( like channel length ) and re-instantiate it in my schematic, retaining the instance names, orientation, etc. Also in the opened schematic, I add power pins.
Now, all the parts of the code is working as intended, But I get the following message in CIW window :
INFO (SCH-1170): Extracting "MY_SCH_NAME schematic"
*WARNING* (DEBASE-102137): deGetViewType - Not a valid windowid.
*Error* rexMatchp: argument #2 should be either a string or a symbol (type template = "tS") - nil
t
I do not get this error when I have the schematic window open. I get this error only when I am operating on an entire library which has many cells.
Here's the piece of code that does it :
cv = dbOpenCellViewByType(convertLib cell~>name "schematic" "" "a")
        ; Re-Instantiate all the transistors and update CDF
        reInstantiateTransistors( cv targLib targLibId targLibCells copyParams channelL )
        printf("Done Re instantiating transistors\n")
        setBulkNode(cv)
        updateCDF_params(cv)
;; In this procedure I iterate do the following
;; if my cellName matches with nch or pch
;; cdfgData=cdfGetInstCDF(inst)
;; Iterate through cdfgData~>parameters list and perform callbacks
        printf("Done updating CDF\n")
        schCheck(cv)
        dbSave(cv)
I would appreciate any help to understand what I'm doing wrong, it works without any issues when i'm operating the same code with a schematic window open.
PS : I have only attached a part of code, but i'm happy to provide the full code, depending on what info might be needed.
Abhi
    Andrew Beckett over 7 years ago in reply to abhi10 +1
    Hi Abhi, Can you try doing: schUnregPostCheckTrigger(' _tpoBcaAutoGenConst ) and see if that fixes it? That function is not a Cadence function, so that's the one I'm wondering might be the reason…
  • abhi10
    abhi10 over 7 years ago in reply to Andrew Beckett
    Awesome! Thank you for following up on it!
    Appreciate the help
    Abhi
