  3. schCheck(cv) warnings and errors after updating CDF par...
  • Replies 11
  • Views 8814
schCheck(cv) warnings and errors after updating CDF params
abhi10
abhi10 over 7 years ago
Hi all,
I am trying to port schematics from one technology to another, and I edit certain transistor parameters ( like channel length ) and re-instantiate it in my schematic, retaining the instance names, orientation, etc. Also in the opened schematic, I add power pins.
Now, all the parts of the code is working as intended, But I get the following message in CIW window :
INFO (SCH-1170): Extracting "MY_SCH_NAME schematic"
*WARNING* (DEBASE-102137): deGetViewType - Not a valid windowid.
*Error* rexMatchp: argument #2 should be either a string or a symbol (type template = "tS") - nil
t
I do not get this error when I have the schematic window open. I get this error only when I am operating on an entire library which has many cells.
Here's the piece of code that does it :
cv = dbOpenCellViewByType(convertLib cell~>name "schematic" "" "a")
        ; Re-Instantiate all the transistors and update CDF
        reInstantiateTransistors( cv targLib targLibId targLibCells copyParams channelL )
        printf("Done Re instantiating transistors\n")
        setBulkNode(cv)
        updateCDF_params(cv)
;; In this procedure I iterate do the following
;; if my cellName matches with nch or pch
;; cdfgData=cdfGetInstCDF(inst)
;; Iterate through cdfgData~>parameters list and perform callbacks
        printf("Done updating CDF\n")
        schCheck(cv)
        dbSave(cv)
I would appreciate any help to understand what I'm doing wrong, it works without any issues when i'm operating the same code with a schematic window open.
PS : I have only attached a part of code, but i'm happy to provide the full code, depending on what info might be needed.
Abhi
    Andrew Beckett over 7 years ago in reply to abhi10 +1
    Hi Abhi, Can you try doing: schUnregPostCheckTrigger(' _tpoBcaAutoGenConst ) and see if that fixes it? That function is not a Cadence function, so that's the one I'm wondering might be the reason…
  • RiadKaced
    RiadKaced over 7 years ago
    Hi Abhi,
    It's going to be hard to debug this error with just a snippet of your SKILL code. If you are not able to share the entire code then I would advise leveraging the SKILL IDE's debugging features like breakpoints. The idea is to understand where the code braeaks when you are parsing an entire library.
    Riad.
    Andrew Beckett over 7 years ago in reply to RiadKaced
    One possibility (given the errors and warnings displayed) is that your environment has a custom post-check trigger enabled, and that is poorly written to expect a window to be open.
    Can you check what schGetPostCheckTriggers() returns?
  • abhi10
    abhi10 over 7 years ago in reply to Andrew Beckett
    This is what I get :
    ("_ciSchPostCheckTrigger" "_schAMSPostCheck" "_schOIPostCheck" "_schRunCustomChecks" "_tpoBcaAutoGenConst"  "_schCICheck" )
    I am fairly new to SKILL , I would appreciate as much help and to code efficiently.
    The other issue is that Although I see this error and warning, All my schematics in the library has been correctly updated, and I can CDL out without any errors / warnings. I really fail to understand what is happening.
    I would appreciate if you could help me understand this.
    Thank you very much
    Abhi
  • abhi10
    abhi10 over 7 years ago in reply to RiadKaced
    Hi Riad,
    Thank you very much for responding to my post. I will give the SKILL IDE a try and see what might be causing this. I would be happy to share the whole code here, but I'll have to redact some things and format it correctly. I will do so in sometime.
    Hi Abhi,
    Can you try doing:
    schUnregPostCheckTrigger('_tpoBcaAutoGenConst)
    and see if that fixes it? That function is not a Cadence function, so that's the one I'm wondering might be the reason. It is (I think) registered by certain TSMC PDKs - I don't know which you're using so I can't check the code. Let's start by seeing whether unregistering the function cures the problem, and if it does, please let me know which TSMC PDK  you're using and I can investigate and we can feed this back to TSMC (or you can).
  • abhi10
    Thank you very much for your response. We are using TSMCN5 PDK.
    I did do what you suggested and the errors and warning went away!
    Done updating CDF
    INFO (SCH-1170): Extracting "MY_SCHEMATIC schematic"
    t
    This is awesome, I would have never guessed any of this.
    Andrew, would it be ok to send you an email with the exact PDK version for us to report and feed this back to TSMC ? I won't be able to post the PDK details in here.
    Abhi
    Sure - happy for you to do that Abhi.
  • abhi10
    I somehow can't send you an email through here, I have sent you a friend request on here so that I can share the details with you.
    Please let me know if that is ok, or if there's another way for me to send it to you.
    Thanks for your help !
    Abhi
    I did accept the friend request, and sent a reply message that way (hopefully you got it - not sure how good the notifiers are as I virtually never use this aspect of the forums because I prefer people to post in public as generally I don't have the bandwidth to respond to individual requests - this is a reasonable exception).
    Andrew Beckett over 7 years ago in reply to Andrew Beckett
    Hi Abhi,
    I've reproduced the problem with the PDK reference you provided me and identified what is wrong. I've alerted our foundry team and asked then to follow it up to get this corrected.
    As you said though, the error should be benign - it would not stop the check from happening, it just means that some of the foundry's auto-constraint generation won't work (but you may not need that).
    Kind Regards,
