  3. Programming help
  • Replies 12
  • Views 18997
Programming help
blankman
blankman over 7 years ago
    Andrew Beckett over 7 years ago in reply to blankman +1
    metals=setof(lpp allLPPs member(car(lpp) list("M1" "M2" "M3")) && techIsLPValidBase(techGetLP(techFile lpp))) or: metalPat=pcreCompile("^M[1-3]$") metals=setof(lpp allLPPs pcreExecute(metalPat car…
    To be honest, you could probably just do:
        metals = setof(lpp allLPPs member(car(lpp) list("M1" "M2")) )
    Don't bother with the valid check (if that is the problem - not sure why it would be, but worth trying).
  • blankman
    blankman over 7 years ago in reply to Andrew Beckett
    Andrew, yep, that did the trick, all sorted, thanks for yeer help, appreciated, Brian.
