  3. Programming help
  • Replies 12
  • Views 18984
Programming help
blankman
blankman over 7 years ago
    Andrew Beckett over 7 years ago in reply to blankman +1
    metals=setof(lpp allLPPs member(car(lpp) list("M1" "M2" "M3")) && techIsLPValidBase(techGetLP(techFile lpp))) or: metalPat=pcreCompile("^M[1-3]$") metals=setof(lpp allLPPs pcreExecute(metalPat car…
  • ebecheto
    ebecheto over 7 years ago
    One example below. There are many of other possibilities.
    Regards
    M="M1"
    metals = list(list(M "drawing")
    (foreach mapcar nb linRg(1 9 1) list(M sprintf(nil "drawing%d" nb))))
  • blankman
    blankman over 7 years ago in reply to ebecheto
    Andrew Beckett over 7 years ago in reply to ebecheto
    How about:
    allLPPs=foreach(mapcar lp techFile~>lps list(lp~>name lp~>purpose))
    drawPat=pcreCompile("^drawing")
    metals=setof(lpp allLPPs car(lpp)=="M1" && pcreExecute(drawPat cadr(lpp)))
    This will find all the purposes that begin with "drawing" for M1. You can change the pattern to suit your needs.
    Andrew Beckett over 7 years ago in reply to Andrew Beckett
    You could also have a wider approach (any purpose) and then just check the validity:
    metals=setof(lpp allLPPs car(lpp)=="M1" && techIsLPValidBase(techGetLP(techFile lpp)))
  • blankman
    blankman over 7 years ago in reply to Andrew Beckett
    Ok, thanks Andrew, and how would I write this then for multiple metals, say M1 M2 & M3? Brian.
  • blankman
    blankman over 7 years ago in reply to blankman
    ie when using the wider approach method
    or:
    metals=setof(lpp allLPPs pcreExecute(metalPat car(lpp)) && techIsLPValidBase(techGetLP(techFile lpp)))
    Or some combination of this and the earlier pattern-based purpose matching.
  • blankman
    Probably best to debug to see if your metals list has these purposes in or not? If using the SKILL IDE you could put a breakpoint after the metals variable has been set and then run the code and it will stop there, and then you could type "metals" (without the quotes) in the CIW to see what the variable contains? You might need to check whether techIsLPValidBase is returning t or not for that LPP. Not sure why it wouldn't given that I wouldn't expect it to appear in the palette otherwise.
  • blankman
    Àndrew, I notice it is stopping at "fill" on all layers
