  3. How to select all items for a sub tree when I click its...
  • Views 15776
How to select all items for a sub tree when I click its parent item?
iDave
iDave over 7 years ago
Hi all
The following is the test code.
root=hiCreateTree(‘root)
item1=hiCreateTreeItem(‘item1 list(“count”))
item2=hiCreateTreeItem(‘item2 list(“name”))
hiTreeAppendItems(root list(item1 item2))
tree1=hiCreateTree(‘tree1)
tree2=hiCreateTree(‘tree2)
hiItemInsertTree(item1 tree1)
hiItemInsertTree(item2 tree2)
for(i 1 1000
    count=concat(“num” i)
    hiTreeAppendItem(tree1 hiCreateTreeItem(count list(artMakeString(i))))
    name=concat(“name” i)
    hiTreeAppendItem(tree2 hiCreateTreeItem(name list(artMakeString(i))))
treeFiled=hiCreateTreeTable(
    ?name ‘treeField
    ?headers list(list(“info” 50 ‘center ‘string t))
    ?choice root
form=hiCreateAppForm(
    ?name ‘form
    ?fields list(list(treeField 5:5 300:300 0))
hiDisplayForm(form)
After the form pop-up, I click the item “name” , how to make all sub items for “name” selected?
Any help will be appreciated.
Dave
    Dave,
    This does it. Not sure it's a good idea though (it's rather slow - the slowness is when using hiTreeTableSelectItems with lots of items - if this is a problem in your real application, please contact customer support).
    root=hiCreateTree('root)
    item1=hiCreateTreeItem('item1 list("count"))
    item2=hiCreateTreeItem('item2 list("name"))
    tree1=hiCreateTree('tree1)
    tree2=hiCreateTree('tree2)
    for(i 1 1000
        count=concat("num" i)
        name=concat("name" i)
    treeField=hiCreateTreeTable(
        ?name 'treeField
        ?headers list(list("info" 50 'center 'string t))
        ?choice root
        ;?callback "CCFselectTreeMembers(hiGetCurrentForm()->treeField)"
        ?callback "CCFselectTreeMembers"
        ?name 'form
    procedure(CCFselectTreeMembers(fieldName selection)
        let((tree newSelection field)
    	field=get(hiGetCurrentForm() fieldName)
    	newSelection=copy(selection)
    	foreach(item selection
    	    tree=hiGetTree(symeval(item))
    	    when(tree
    		newSelection=append(newSelection hiGetTreeItems(symeval(tree)))
    	; select items but don't trigger callback again
    	hiTreeTableSelectItems(field newSelection nil)
    hiDisplayForm(form)
  • iDave
    iDave over 7 years ago in reply to Andrew Beckett
    This is what I want.
    thank you.
