  3. Auto-wiring with narrow width for the bus after pressing...
  • Views 18716
Auto-wiring with narrow width for the bus after pressing space in schematic?
oyayla
oyayla over 7 years ago
When I select a symbol in Virtuoso Schematic and press the space in the keyboard, Cadence adds the wires around the symbol and for buses, it uses wide width. Is there a way to make default selection as narrow width?
yayla
    Andrew Beckett over 7 years ago in reply to RiadKaced +1
    Yayla, Riad, You can control this via the Options->Editor form: Or via cdsenv: envSetVal("schematic" "autoWireStubBusTerms" 'cyclic "narrow") ; the default is "wide" Regards, Andrew.
  • RiadKaced
    RiadKaced over 7 years ago
    Hi Yayla,
    The SKILL function behing the scene for adding wire stubs on instances is schHiCreateWireStubs(). This function does not take any argument/option as per the documentation, therefore there is no way for you to customize the width of the bus. You may want to file a ticket for Cadence to provide a switch for that. Meanwhile, Cadence provided CCSaddWire.il which you can customize to your needs. I'll leave to Andrew for further comments.
    Cheers,
    Riad.
    Yayla, Riad,
    Or via cdsenv:
  • oyayla
    oyayla over 7 years ago in reply to Andrew Beckett
    Hi Riad, Andrew,
    Thanks for the answers.
    After changing the setting as Andrew mentioned, I was able to get what I was looking for.
    yayla
