  3. how to access the mtOptions with skill
  • Views 15189
Rick Mattern
Rick Mattern over 6 years ago
having an issue with a skill routine.    I have a ticket open with CDS but havent got a solution yet.   I have routine that replicates the runSimulation file from the ADE/ADEXL GUI in a known location which works except for one condition.   The HPOptions form when set to manual  can either be set to  an integer or lsf or sge.    Ive tried various syntax in the code which reads ok but when executed gets
testSession: sevSession20 asiSession: stdobj@0x259a8788
*Error* eval: unbound variable - lsf
Heres a snipet of the code.
if( numThreads =="lsf" then
multiThread = "+mt"
Any ideas on what it should be or how to find the correct arguement?
    I'm a bit reluctant to repeat work that is going on by a colleague on your case. Please state the case number and I'll take a look.
    Note, the issue can't be with the snippet of the code you've given, so hopefully you've provided more info in the support case? If not, you'll need to.
  • Rick Mattern
    Rick Mattern over 6 years ago in reply to Andrew Beckett
    Hi Andrew - the case number is 46387639     The skill routine is attached to the ticket.
    any help would be appreciated
    Andrew Beckett over 6 years ago in reply to Rick Mattern
    Rick,
    I've just sent a response via the case. The error was indeed nowhere near the portion of code you posted above - but I've given you some suggestions.
