  3. How to set system variable in CIW window
  • Views 21144
ExcaIibur
ExcaIibur over 6 years ago
The use scenario is that I want to load some ocean script from the CIW window with the syntax load("filename.ocn")
And in the ocean file, some system variable is quired, e.g. env(cellName)
However, I discovered that, if I defined the system variabler cellName after I launch virtuoso, then virtuoso cannot see this variable.
I would like to know whether what I observed is true and if true how to work around that.
    Andrew Beckett over 6 years ago +1
    Assuming you're talking about UNIX environment variables, then setting a UNIX environment variable will not affect any child process previously launched from the process where you set the env var - this…
    Assuming you're talking about UNIX environment variables, then setting a UNIX environment variable will not affect any child process previously launched from the process where you set the env var - this is how UNIX works.
    You can set a UNIX environment variable in SKILL using:
    setShellEnvVar("THEVARNAME" "myvalue") ;
    and getShellEnvVar("THEVARNAME") would retrieve.
    Perhaps that's what you want?
  • ExcaIibur
    ExcaIibur over 6 years ago in reply to Andrew Beckett
    I just tested it and indeed it did exactly what I want. Thanks for the information.
