  3. SKILL enhancement: How to keep the function active until...
  • Views 16585
SKILL enhancement: How to keep the function active until Escape key is pressed
ssram
ssram over 6 years ago
I've got the following script to add markers in the layout.
Calling the function srCreateLayMarker() would keep it active until i click on the layout, and it goes away. How can i make this function stay active until an escape key is pressed?
Ram
procedure(srCreateLayMarker( @optional (pt nil) (cv geGetEditCellView()) )
let((mid lbl_txt lbl )
unless(cv && cv~>cellViewType=="maskLayout"
error("A layout cellview must be open to create the marker at current location")
unless(pt
pt=hiGetPoint(hiGetCurrentWindow())
sprintf(lbl_txt "%L %L" car(pt) cadr(pt))
mid=dbCreateMarker(cv "marker" "srCreateLayMarker" list(pt) )
lbl= dbCreateLabel(cv list("y0" "drawing" ) pt lbl_txt "centerLeft" "R0" "roman" 0.1)
lbl~>parent=mid
);let
);proc
hiSetBindKey("Layout" "F10" "srCreateLayMarker()")
  • mbracht
    mbracht over 6 years ago
    Hi Ram,
    I don't really understand what you mean with "Calling the function srCreateLayMarker() would keep it active".
    I tried your code - as long as the mouse pointer is in a layout window and I click F10 (the bindkey...) it works perfectly well for me. Calling the function manually from the CIW throws an error because hiGetPoint(hiGetCurrentWindow()) returns nil when the mouse pointer  is not in the layout window. This leads subsequently to an error in dbCreateMarker(..) then.
    So as I said I don't exactly understand your question but if you change the unless() statement to
    unless(pt
                pt = hiGetPoint(hiGetCurrentWindow()) || (0:0))
    ...you will be able to call the function either though the bindkey or manually from the CIW.
    Max
    Andrew Beckett over 6 years ago in reply to mbracht
    Ram,
    I suspect that what is really wanted here is to use enterPoints() and then have the code be triggered on each point that is added until escape is pressed. That's going to be the easiest solution. There are a number of other similar posts on the forums - search for "enterPoints" or "enter function" for more details. Or look in the documentation for enterPoints.
  • ssram
    ssram over 6 years ago in reply to Andrew Beckett
    Thanks Andrew.
