  3. Clear netName for all objects in cellview
  • Views 16821
Mahesh gunde 1
Mahesh gunde 1 over 6 years ago
Hi All,
Purpose: I want to clear the netname for objects,shapes if its in group or clone as well
I have tried in different ways to clear net name using skill.
eg:
1.dbRenameNet function
2.geGetSelSet()~>net~>name = ""
3.geGetSelSet()~>net~>name = nil
Nothing works for me can anyone help me on this?
Mahesh
    Hi Mahesh,
    geGetSelSet()~>net=nil
    will do it (unless the figures are part of a route, in which case I think you have to delete the route object, using dbDeleteObject(fig~>route)). You can also use dbSubFigFromNet(fig) - again, assuming it's not part of a route.
  • Mahesh gunde 1
    Mahesh gunde 1 over 6 years ago in reply to Andrew Beckett
    Thank you so much for your information.
    fig~>route returning nil.
    do we have any other procedure or functions to clean the net name.
    Mahesh
    Andrew Beckett over 6 years ago in reply to Mahesh gunde 1
    Mahesh,
    I told  you this already. You can either set fig~>net=nil or dbSubFigFromNet(fig) - this removes the figure from the net, and so if you edit properties on the shape, it won't have a net name.
    The only restriction was if the figure was part of a route, because you'd get a message telling you that you can't remove the figure from a net if it's part of a route. It's not part of a route in your case so that restriction doesn't apply.
  • Mahesh gunde 1
    Thanks for your quick response and information.
    Mahesh
