  3. libInit.il file
  • Subscribers 150
  • Views 17538
libInit.il file
wenckey
wenckey over 6 years ago
In my cds.lib there will be a lib named alib and defined the path.
Under alib there is a libInit.il file in it.
When I start virtuoso, will the file be loaded automatically?
Seems some time it will load, but sometime it not.
    Andrew Beckett over 6 years ago +1
    It will be loaded the first time the library is accessed, not at startup. Regards, Andrew.
  • Sheppie
    Sheppie over 6 years ago +1
    Hi, What I usually do if I want the libInit.il file to be loaded at start-up, is the following: techGetTechFile( ddGetObj( "alib" ) ) This will access the library and thus load the libInit.il file…
  • Sheppie
    This will access the library and thus load the libInit.il file (as Andrew mentioned).
    Sjoerd
