  3. PCell Evaluation failed on GDS Stream out.
  • Views 19106
Christian Wieden
Christian Wieden over 6 years ago
Hello All,
i have the following Problem, then i try to stream out a PCell i am working on, i get the following error from Virtuoso:
*WARNING* (DB-270001): Pcell evaluation for SG25_dev/sealring_complete/layout has the following error(s):
*WARNING* (DB-270002): ("eval" 0 t nil ("*Error* eval: unbound variable" PDK_LIBRARY))
*WARNING* (DB-270003): Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
ERROR (XOASIS-231): Pcell evaluation failed for 'SG25_dev/sealring_complete/layout' because the Pcell SKILL code contains either a syntax error or an unsupported XOasis function. Check the standard output or the Virtuoso log file for more information. Either correct the Pcell SKILL code or ignore the error by enabling the 'ignorePcellEvalFail' option for XOasis Out.
But then i load the Skill code no error is reportet, in the Layout view no marker is found.
load "sealring_complete.il"
Generating Pcell for 'sealring_complete layout'.
t
Also boundp reports that PDK_LIBRARY exists and printing the Content of PDK_LIBRARY shows a correct value.
boundp('PDK_LIBRARY)
t
dprint PDK_LIBRARY
PDK_LIBRARY = "SG25_dev"
t
Best Regards,
Christian Wieden
  • mbracht
    mbracht over 6 years ago
    Hi Christian,
    The stream out does not run in the same context like virtuoso does. Tthe fact that you see that variable during a virtuoso session does not necessarily mean that its visible in the stream out too.
    So where is this variable being set? To confirm that suspicion you might hard code the variable with in the pcDefinePcell() function in sealring_complete.il, then recompile the pcell and try the stream out all over again.
    Max
  • Christian Wieden
    Christian Wieden over 6 years ago in reply to mbracht
    Hi Max,
    then i hardcode PDK_LIBRARY="SG25_dev" into the pCell then  it works without a Problem.
    PDK_LIBRARY is set in cdsinit, is there a better place to define this library?
    Best Regards,
    Christian
  • Christian Wieden
    Hi All,
    i talked with my colleagues, after trying to put PDK_LIBRARY into libInit instead of cdsinit it seems to work fine now.
    Thanks to Max for the help and pointing us at the right direction.
    Best Regards,
    Christian
  • mbracht
    mbracht over 6 years ago in reply to Christian Wieden
    well one way would be to set it as a Unix environment variable and then set the SKILL variable in pcDefinePcell() accordingly:
    (setq PDK_LIBRARY (getShellEnvVar "PDK_LIBRARY"))
    Max
