  3. Ocean parametric sweep fail due to memory
  • Views 15734
Peter Madsen
Peter Madsen over 7 years ago
Hi All,
I am running an parametric sweep as a parametric set with a total of 9 sweep parameters. The total number of sweeps are 144
I am running a DC, SP and a two tone HB analysis.
After 122 sweeps the simulation crashes due to memory limitations as spectre alocates 27.9 GB on a 32 GB machine.
This is okay if the analysis needed that amount of RAM, but running the settings for the sweeps as a stand alone simulation uses less than 5 GB
It seems there is a bug in the parametricrun() command as simulation data never leaves memory.
Is there a way force the data out of memory between each run?
Another way of fixing this is to split up the sweep in smaller sweeps  in a for loop, but I would like to avoid this.
I am using spectre version 18.1.0.370.isr7 64-bit
Hope some can help,
Peter
    I'm not sure why the memory should grow - you should contact customer support about that.
    I was thinking that you could just use: envSetVal("spectre.envOpts" "controlMode" 'string "batch")
    at the beginning of your OCEAN script, but with paramset it still runs a s a single invocation of spectre (conventional parametric analysis would invoke spectre separately for each run).
    You could use ADE XL or ADE Assembler instead. You define the individual variables as a list of the values you wish you sweep, and then select the variables in the list of global variables and use Right Mouse->Group as Parametric Set. If you do it this way, each simulation will be an individual run and so the memory should not accumulate.
  • Peter Madsen
    Peter Madsen over 7 years ago in reply to Andrew Beckett
    Hi Andrew
    Thanks for your suggestion with the env option. This didn't change the memory growth.
    So I have contacted cadence support.
    Peter
