  3. *Error* putprop: first arg must be either symbol, list,...
  • Subscribers 150
  • Views 13093
*Error* putprop: first arg must be either symbol, list, defstruct or user type - nil
wgtkan
wgtkan over 6 years ago
When I try to instantiate a transistor, I get the following error:
*WARNING* (SCH-1156): CDF parameter function has a problem.
("nmos4")
My virtuoso version is:sub-version IC6.1.8-64b.500.1
I looked up the forum and there was similar issue years back as posted here:https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/22865/launch-lehicreateinst-it-shows-error-putprop-first-arg-must-be-either-symbol-list-defstruct-or-type-nil
I tried the suggested methods but no luck.
Thank you so much.
    Can you try doing:
    tracelength=tracelevel=_stacktrace=50
    and then using the schematic editor create instance command (the other post was about layout, so isn't directly applicable). This seems to be a bug in one of the CDF callbacks of the component you're instantiating, so it's very likely to be specific to the PDK or component you're using, rather than a Virtuoso bug.
    I'm hopeful that the above might give more of a clue as to which callback function is failing. If that doesn't help, you might also need to do:
    sstatus(errsetTrace t)
    and try again. Please post the CDS.log file entries you see having done this...
  • nktty
    nktty over 4 years ago in reply to Andrew Beckett
    Hi Andrew, I tried using slicer command but receive error. Do you have any idea on how to fix this?  ->*Error* putprop: first arg must be either symbol, list, defstruct or user type - array@0x2bd0ad0a038
    Andrew Beckett over 4 years ago in reply to nktty
    I see from your other post that you’re using Allegro. The root cause will therefore be different than this - which was coming from Virtuoso. I moved your other post into the correct forum.
