  3. Skill solution for smartSnap in layout
  • Views 16449
ssram
ssram over 6 years ago
Most of the layout functions have now got a smartSnap option.
For example:
for "leHiCreateRect()", we have the following to turn the smartSnap on/off
leRectXLForm->rectSmartSnapEnable->value= t
leRectXLForm->rectSmartSnapEnable->value= nil
for "leHiCreateRuler", we have the following to turn the snap option on/off
ruler->rulerSnapOff->checked=t
ruler->rulerSnapEdges->checked=t
So, i was thinking if i could set a global bindkey to turn the smartSnap on/off for all such functions. What i mean is, when the "leHiCreateRect()" is active pressing the bindkey for example "Shift<Key>s" would toggle the smartSnap for it on/off and if the function "leHiCreateRuler" is active, the same bindkey "Shift<Key>s" would toggle the smartSnap on/off for it.
Can anyone help out with a SKILL solution? I think its a good to have feature built in Cadence tool itself.
Ram
  • sedersingh
    sedersingh over 6 years ago
    [deleted]
  • ssram
    ssram over 6 years ago in reply to sedersingh
    Hey, i'm using the IC18.1.7
    Andrew Beckett over 6 years ago in reply to ssram
    I'm not sure what version is IC18.7 (there's no such version), but I think you could call this function on a bind key - and it could be extended for other commands potentially:
    procedure(CCFtoggleSnap(@optional (win hiGetCurrentWindow()))
      let((current)
        case(hiGetCurrentCmd(win)
          ("Ruler"
            current=ruler->rulerSnapOff->checked
            ruler->rulerSnapOff->checked=!current
            ruler->rulerSnapEdges->checked=current
          ("Rectangle"
            leSetEnv("rectSmartSnapEnable" !leGetEnv("rectSmartSnapEnable"))
    Simply load the code, and then have CCFtoggleSnap() on your bind key.
  • ssram
    ssram over 6 years ago in reply to Andrew Beckett
    Thanks Andrew, its the IC18.1 version
