  3. How to resize a layout window and do zoom-to-fit through...
  • Subscribers 150
  • Views 18035
How to resize a layout window and do zoom-to-fit through skill
Jameel Ahmed
Jameel Ahmed over 6 years ago
I need to resize an open layout window to a size, say 1400X1500 and display the  entire design in that window automatically.
I am using the code below, the resize works but the zoom to fit is not happening.
hiResizeWindow(hiGetCurrentWindow() list(0:0 1400:1050))
hiUpdate()
hiZoomAbsoluteScale(hiGetCurrentWindow() 0.9)
hiUpdate()
I have experimented in adding a sleep(3) after the hiResizeWindow function call above and it seems to work but fails intermittently. Is there way to cleanly do this without using sleep ?
Jameel
  • franck tellier
    franck tellier over 6 years ago
    Hi Jameel ,
    you can try to delay the beginning of the zoom fonction with the following syntax :
    hiRegTimer(  "hiZoomAbsoluteScale(hiGetCurrentWindow() 0.9) hiRedraw() " 1 )
    Regards
    Franck.
  • Jameel Ahmed
    Jameel Ahmed over 6 years ago in reply to franck tellier
    Thanks Frank, that works!
