  3. How to sort instances in layout based on instance name?
  • Replies 7
  • Subscribers 152
  • Views 19884
ssram
ssram over 6 years ago
How can i sort instances in layout based on instance name?
For example, if i've 50 instances named "inv<0:49>", how do i sort them all based on the instance name in an ascending/descending order?
Is there an built-in function that can do this? Or anyone has got a SKILL solution/approach to this?
Ram
    By sort, do you mean to sort them physically (so they are placed in order, left to right or top to bottom)? Or do you just mean sort a SKILL list of such instances?
    If it's the latter, then:
    listOfInsts=sort(listOfInsts lambda((a b) minusp(alphaNumCmp(a~>name b~>name))))
  • ssram
    ssram over 6 years ago in reply to Andrew Beckett
    Yes, sort them physically and place them in a row.
    Ram
    Andrew Beckett over 6 years ago in reply to ssram
    I don't have any code that does that, but having sorted the list of instances as above, you could step through the list updating the ~>xy of each instance to an incrementing location, so it would be easy enough to write...
  • ssram
    Finally... looks like there's a built-in function in the tool itself. It was hiding inside Align option, took some time figure it out.
    Thanks!
  • kumargbn
    kumargbn over 5 years ago in reply to Andrew Beckett
    I am writng a code to join two bus connections. horizontal and vertical.
    Is there a way to sort the path list with the BBOX> sometime while selecting the order is very random.
    Please let me know how to sort a path list using bbox or begin pt or end pt.
    Nirmal.
    Andrew Beckett over 5 years ago in reply to kumargbn
    Nirmal,
    This doesn't appear to have a great deal to do with the original topic of this old post (other than both having the word "sort" in them), and the forum guidelines ask you not to post on the end of old threads anyway. I suggest you start a new thread.
  • kumargbn
    Thank you for your reply. I have started a new thread for the above query.
    Nirmal.
